Technical T&A hump spring to flat????
Discussion in 'The Hokey Ass Message Board' started by 2FORCEFULL, Sep 16, 2024.
  1. ALLDONE
    ALLDONE
    does a 35 ford work???? as in is the spring from the 35 a bolt in swap???
  2. alchemy
    alchemy
    A 35 spring in an A crossmember? Only if you have VERY strong spring clamps.
  3. ALLDONE
    ALLDONE
    I ment in the spring perch
  4. alchemy
    alchemy
    A 35 spring on an A axle? Probably won’t have much travel before bottoming out.
  5. '29 Gizmo
    '29 Gizmo
    from UK
    It's arched for a reason.
