Hot Rods T body on A frame
Discussion in 'The Hokey Ass Message Board' started by Truckedup, Oct 22, 2014.
  1. Truckedup
    Truckedup
    I have a stock 31 Model A complete running ch***is/engine. I plan to build a bare bones "speedster" so I need a cowl section. A guy locally has a 26 Model T body tub in usable shape for a nice price....
    Will the t fit on the A without a lot of metal work?
  2. need louvers ?
    need louvers ?
    It'll go without too much messing around. The thing to remember is that the "A" has a 3 1/2" longer wheel base over the "T"... Although in a typical speedster situation that shouldn't matter.
  3. Hdonlybob
    Hdonlybob
    Yes it will work with minor modifications.
    I put a '26 T Coupester body on a Model A frame...
    Good luck..
  4. gimpyshotrods
    gimpyshotrods
    Yup, you put that next space in the engine bay, for your early hemi.
  5. Squablow
    Squablow
    Yes, it'll fit nicely. If the wheels need to line up with rear wheelwells (depends on what body you're using), a '40 spring behind style rearend might make up for the 3" different wheelbase. My '26 is on an A frame but with a '25 style turtle deck so there's no rear wheelwell to align.
  6. Hitchhiker
    Hitchhiker
    The biggest problem is the pedals and firewall. I think it's best to forget the wheel well alignment. And position the body so the pedals will work with the firewall.
    These aren't great pictures, but it's a model t on a A ch***is.
  7. Truckedup
    Truckedup
    Thanks, It's just going to be the front cowl mostly with the seats out in the open. If using a hood the A hood can be m***aged to fit ok?
  8. Tony, the T cowl is lower than the A radiator and shell. JW
  9. Truckedup
    Truckedup
    Ohhh, the guy who owns the A ch***is has a new stock radiator.....Might be best to wait for an A cowl to come along...
  10. What year A is the radiator for? You could space the cowl up a bit, mine was spaced up before I got it and im just going to use a filler piece on the ch***is. JW
  11. Truckedup
    Truckedup
    The radiator is for a 1931...
  12. ROADSTER1927
    ROADSTER1927
    That is the tallest one, not good in your case. Gary
  13. Leon Sandcastle
    Leon Sandcastle
    Personally I like T's on A frames, especially latter T's. Got any pictures?
