Technical T-bucket axle weight
Discussion in 'The Hokey Ass Message Board' started by Jack Rotts, Oct 18, 2022.
  1. Jack Rotts
    Jack Rotts
    Wondering what might be typical weight of a stripped dropped I-beam axle as found on a t-bucket or similar. Curious how much overweight my chubby mystery axle might be. Trying to manage unsprung weight. Thanks.
  2. Tim
    Tim
    from KCMO
    A model A axle total bare is around 19 lbs I believe
  3. RICH B
    RICH B
    Weighed some axles the other day to answer a question.
    '33-'36 axle = 22.3 lbs
    '32 axle = 24 lbs
    "A" axle = 20 lbs
    Tim likes this.
  4. KenC
    KenC
    Can't answer your question, but if you are a fan of drilled axles, it looks like you have a perfect candidate for lightening holes!
  5. Don't you have a bathroom scale to find the weight for your self ?
    Tman likes this.
  6. RICH B
    RICH B
    So, what does your axle weigh?
  7. Mr48chev
    That is a parallel leaf axle that is probably out of a pickup but could be out of a car with parallel leaves. You can poke around on Sid's dropped axle site and probably get a good idea of what it started life in before it was dropped. Measure the center of spring pin to center of spring pin holes and compare.
    Dropped Axles |
    There was/is a guy in the Cle Elum Wa area who built a couple of wild T buckets back about 30/40 years ago with a similar axle with the batwing setup bolting to the Ubolt holes in the axle.
  8. Tim
    Tim
    from KCMO
    isn’t going to help him if he doesn’t have an A axle to weigh. He wasn’t asking what his existing axles weighs
  9. Budget36
    Budget36
    Regardless of the difference, I wouldn’t think it would affect handling and/or drive characteristics, unless you are doing 170mph turns.
  10. RICH B
    RICH B
    Plenty of old Ford axles out there; no sense messing around with an unattractive Micky Mouse truck axle set-up.
    X38 likes this.
  11. He wants to know how much overweight his axle is compared to others. he needs to know the weight of his axle to answer his question.
