T-Bucket battery mount
Discussion in 'The Hokey Ass Message Board' started by travj31, Dec 27, 2008.
  1. travj31
    travj31
    from Western PA
    I'm building a bucket without a small bed in the back, any suggestions where I should mount the battery?
  2. Chicken Scratch
    Chicken Scratch
    Did you mount your gas tank yet? Mount it in the bed if the gas tank didnt take up all the room. If there's no room there, get a red top gel cell battery and mount it on its side up under the p***enger side of the dash.
    If you have the gronud clearence you can get a frame rail mount and mount it under the bucket.
  3. Flatman
    Flatman
    Any room in the floor under the p***enger seat?
    Flatman
  4. t-buckethead
    t-buckethead
    from texas
    under the seat,mounted to the frame on the p***enger side.cut a whole in the floor for access.thats how i mounted mine in my bucket.
  5. propwash
    propwash
    from Las Vegas
    Doesn't anybody READ what he asked? My take on it is he doesn't HAVE a bed to mount things in, so any suggestions on just where to put it in the bed are pretty much useless - or at least not pertinent.
    dj
  6. Phil1934
    Phil1934
    Honda batteries are about 7"x3"x6". Get a brand you can lay on its side and put it under the floor.
  7. timmy t
    timmy t
    mounted mine under the dash on my modified. its an optima so its rather large but i made a bracket with a door hinge on one end so I can swing it down to get at it.
  8. Put it under your seat. Mikey
  9. swade41
    swade41
    from Buffalo,NY
    I made a cardboard box the size of the battery and went under the car until I found a place that was unobtrusive, happened to be under the p***enger seat. The red top sealed batteries can be put on their sides for even more clearence.
    Just Gary likes this.
  10. travj31
    travj31
    from Western PA
    thanks...i've heard about mounting batteries upside down or on the side, but i was a lil skeptical at first
  11. Belchfire8
    Belchfire8
    Yup, they can go upside down, I e mailed Optima and they said it can go in any position including upside down...they are sealed. here's a couple pics of mine mounted under the bed during mock up stages, it's been under there for a couple years no, no probs
      48 KB
      45 KB
  12. 40streetrod
    40streetrod
    from nj
    thanks...i've heard about mounting batteries upside down or on the side, but i was a lil skeptical at first"
    not wanting to be a smart *** here but, you do understand that they are talking about dry gel batteries, right? like Optima batteries or Odyssey batteries
  13. travj31
    travj31
    from Western PA
    yep, i understand!!! thanks for looking out though...
  14. This is why I have a pig pile of empty beer boxes...
  15. 29nash
    29nash
    from colorado
    Mount it by the motor, very ingenious and different.
    It'll draw a lot of interest. People will ask "what is that?":eek:
  16. swade41
    swade41
    from Buffalo,NY
    you have empty beer boxes because you don't have a state tax on each can like here, we use those boxes to take back the cans in...lol
  17. RPM
    RPM
    We mount the battery under the p***enger seat, in the buckets we build.
  18. Ichoptop
    Ichoptop
    the Optima battery is not sealed nor is it a gel style battery. It is an Absorbed Gl*** Mat battery. This means the liquid is absorbed into the cells. It is still a liquid not a gel. The battery is not sealed. Those two little charcoal looking protrusions in the cover are called flame arrestors and are there to cover the vents. The battery will vent a gas but not a liquid.
    So yes, they can be mounted on any axis without issue but they are not a gel battery, a dry battery nor a sealed battery.
  19. Humidi-T
    Humidi-T
    from Louisiana
    I'm with RPM, mine is under the seat, on the p***enger's side, in it's own batttey box with the top of the battery flush with the floor, and the terminal sticking up. I have it all the way against the frame rail.
    These ******s get pretty tight underneath, with battery, transmission, Transmission oil cooler, driveshaft, parking brake cables, horn, master cylinder, and shifter all trying to occupy a square yard of space.
    But damn are they fun!
