t bucket measurment needed
Discussion in 'The Hokey Ass Message Board' started by J Man, Jan 17, 2004.
  1. J Man
    J Man
    from Angola, IN
    I need the measurment for a t bucket body from the outside edge of the firewall to the back of the tub on the outside edge. Thanks.
    Jason
  2. Unkl Ian
    Unkl Ian
    I think those dimensions are avaialable on speedwaymotors.com
    Keep in mind,some of the aftermarket bodies are longer than stock.
  3. J Man
    J Man
    from Angola, IN
    After I get moved I am going to start on my '24 T. I am taking a TT cab and building it t bucket style. What I am trying to find our is if the cab will fit on the standard 103" wheelbase ch***is or if I need a longer one. I plan to use a Buick 455 and 400 ****** (out of same car), a quickchange if my boss will sell it to me affordibly and a 6" tube axle with a spring behind setup. and corvair steering.
    Jason
  4. lowsquire
    lowsquire
    from Austin, TX
    just a guess, but it will probably fit, If your tall, or dont want to chop the firewall, Id add 3-4" through the middle of the ch***is (that is if you plan to build it yourself...)
  5. J Man
    J Man
    from Angola, IN
    I know someone out there has a t bucket that can give me a basic measurement. Thanks
  6. Mutt
    Mutt
    My gl*** body is 52" firewall to back of tub.
  7. J Man
    J Man
    from Angola, IN
    what size ch***is are you using. Thanks for the info.
    Jason
  8. Mutt
    Mutt
    Wheelbase is 101" on a home made ch***is - Spring over in front and the body is notched for the kickup in the rear. (The kickup rails barely intrude - maybe 2")
  9. Jimv
    Jimv
    go to Total performances site, they can help you there or to www.nationaltbucketalliance.com.That site is just bucket heads who can give dimensions of the top of there heads'
    jim
