T-Bucket weight
Discussion in 'The Hokey Ass Message Board' started by RFAGrasshopper, Jan 5, 2012.
  1. RFAGrasshopper
    RFAGrasshopper
    What is the average weight of a T-bucket with a Small Block Ford or Chevy engine. Trying to gather some info for my next project. :D
  2. Mine was officially 1900 pounds. Really. 350/TH400 and not much else.
    Cosmo
  3. fitzee
    fitzee
    I seen them as low as 1500 pounds.. Mine has a BBC and it is 2000.
  4. R Frederick
    R Frederick
    from illinois
    Mine is 2,000 lbs. with a steel body, 305, 350 trans, steel wheels, 16 guage floor and driveshaft tunnel, and a frame way overdone with 2x4 3/16" box. I could have built it at 2,500# easy, but I get carried away with safety.
  5. raidmagic
    raidmagic
    My dads is 2100 with a 283 and HUGE rear tires. Iwill be weighing mine in the next few weeks
  6. flatheadpete
    flatheadpete
    from Burton, MI
    Mine had a Flatty and 5 spd, banjo, glass body....nothin' to it. 1475 with 1/2 tank of gas.
  7. Last edited: Jan 5, 2012
  8. Mine is 1840 with a 350/350 9 inch, glass body steel wheels with bias plys. 960 front and 880 rear, 80 lbs off 50/50 weight distribution.
  9. tfeverfred
    tfeverfred
  10. designs that work
    designs that work
    Steel 26 body, 1.5 x 3 inch x .120 frame, flathead and t5, steel wheels 1840.
  11. roadster1923
    roadster1923
    from Girard PA
    1700 lbs, w/SBC 350 & powerglide.
  12. bobscogin
    bobscogin
    1350 lbs, but mine is short (94" wheelbase) and has a 4.3L Chevy V6 and T5 which is a lot lighter than the usual sbc/th350.
  13. JMel
    JMel
    Mine is 1,880 with a steel body, and 305. Had to sit in it while it was on the scales to get it over 2k lbs so they could get their equipment to print. They couldn't get anything to print under 2k lbs. My fat-ass got it WELL over that 2k limit.
  14. denis4x4
    denis4x4
    from Colorado
    The one in my avatar is 1900 and change. However, '31 banger engine and '39 tranny probably weigh more than a SBC.
  15. one of my old ones weighed in at 1236. Aluminum 215, aluminum powerglide, chromemoly tube frame, fiberglass body, franklin qc, with (at the time) state of the art Motor Wheel Flys. Single seat, center steer, and every bracket, pedal, gusset and flat surface were drilled with lightening holes.
    Turned out not that practical in the real world. Bumps and RR tracks tended to send it airborn if I hit them at any normal speed.
  16. RFAGrasshopper
    RFAGrasshopper
    Thanks for the input. I am looking to use the Speedway '27 frame with a leaf spring hung 9" rear end to build a Street/Strip Tall T. I'll do a Build up on it as soon as I get things rolling. Wasn't there a company down south making a Fiberglass '26-'27 chopped T-Coupe????? Anyone remember who it was?
  17. Blue One
    Blue One
    from Alberta
    Here you go.
    http://www.russnomorestreetrods.com/27coupe.php
  18. RFAGrasshopper
    RFAGrasshopper
  19. gas pumper
    gas pumper
    91 inch WB A frame. banjo. 283. T-5. 'glass. minimal interior. 35 wires. 1740# with 5 gal gas in the tank.
