Hot Rods T-Buckets Or Dragsters...
Discussion in 'The Hokey Ass Message Board' started by LOU WELLS, Dec 31, 2023.
  1. LOU WELLS
    LOU WELLS
    from IDAHO
    415790233_809691261168272_4670578097561683189_n.jpg Is The Line Between T-Buckets And Dragsters Sometimes Thin?...
    Sharpone, EVL401, 69thumper and 13 others like this.
  2. DDDenny
    Lou
    Of the various interest groups of street rodding in the 60's, I've often felt the T- bucket crowd gravitated towards the more serious side of hot rodding culture of the day, big engines, blowers, big/little wheels/slicks, spindle mount wheels, etc.
    Kind of a "if a little is good, too much is just right" mindset.
  3. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    For a while, the /Comp Roadsters were a go between cl***ification, with many famous AA/FD drivers and Funny Car drivers graduating from the Comp Roadster cl*** before it was disbanded.
  4. Dennis D
    Dennis D
    Is he putting regular gas in that?
  5. swade41
    swade41
    from Buffalo,NY
    This used to belong to a friend
    Sharpone, Driver50x, slayer and 7 others like this.
  6. hotrodjack33
    hotrodjack33
    After building/buying a SOHC, all he can afford is cheap gas;).
  7. lake_harley
    lake_harley
    Front suspension is....uh....different.
    Lynn
    Sharpone and LOU WELLS like this.
  8. nrgwizard
    nrgwizard
    from Minn. uSA
    Probably closer to Altered or AA/FA look-alike wannabes...
    Big mill pushed back, rear pushed forward, big rear tires(10x16 slicks were TF tires in the 60's, iirc. etc). Lots drag influence.
    Marcus...
  9. twenty8
    twenty8
    And check out the cowl steering....... with the mid "idler arm???" support setup....o_O
  10. That's just a Rocker arm system and with the coil overs he has shocks without mounting shocks separately. I like it for the street.
    Sharpone, mad mikey and LOU WELLS like this.
  11. If you look closely, you can see the support arm is shorter than the pitman arm. Yes, it's some support but more importantly is speeds up the turn ratio a bit and helps keep you in one lane when turning corners. On a race only Dragster you don't want that going on.
  12. Marty Strode
    Marty Strode
    Those 615 horses will empty that little fuel tank pretty quick !
  13. alanp561
    alanp561
    Eight to one compression. It will be alright ;).
    Sharpone, hotrodjack33 and LOU WELLS like this.
  14. swade41
    swade41
    from Buffalo,NY
    AMT offered a few models like it and here's this article from 75
  15. spanners
    spanners
    I'd be more concerned with the no front brakes on the street.
  16. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    The problem with it on the street is, no one :eek: will offer you a challenge at the red light.
  17. hotrodjack33
    hotrodjack33
    Besides the fact that the Zoomies are aimed in the worst possible direction (their heads), the lack of a cooling system tells me he doesn't need any gas...it DON'T run.:mad:
    Tow Truck Tom and hook00pad like this.
  18. hook00pad
    hook00pad
    I didn't see any evidence of a radiator either.
    Tow Truck Tom likes this.
  19. I think you guys are maybe jumping to conclusions. I clearly see 2 hosses, one top and one off the pump. They are not connected directly together. That would tell me they are headed somewhere to p*** water through something. It may not be much bigger than the Fuel Tank but I bet it helps out a lot. And, there is a belt spinning the water pump pully. I still like it.
    Sharpone, Tim and mad mikey like this.
  20. I agree, he should have stopped at the Supreme pump.
    Sharpone and Stan Back like this.
  21. dana barlow
    dana barlow
    from Miami Fla.
    Should be go to go around the block,before over heating.
    Sharpone, Tow Truck Tom and alanp561 like this.
  22. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    I gave this a like be-cuz, then I look some more.
    The lady p***enger's face tells me, It Runs.
    :mad:
    Sharpone, mad mikey and chevy57dude like this.
  23. swade41
    swade41
    from Buffalo,NY
    Car Craft March 1968 has the article on that car, I remember reading and believe the coolant is ran through the ch***is.
    There was a discussion here on the HAMB quite a few years ago about drag racing t-buckets, I think it was around the time I got mine on the road so probably 2007 or 2008 maybe.
    rod1, Sharpone, Driver50x and 4 others like this.
  24. spanners
    spanners
    I bet he doesn't take it through the drive-thru car wash.
    Sharpone and Pist-n-Broke like this.
  25. hotrodjack33
    hotrodjack33
    LOL. You may be right...that ain't no happy face:mad:.
    Sharpone and Tow Truck Tom like this.
  26. twenty8
    twenty8
    Twin supine-mounted radiators under the cab.
    At least that is what it says here:
    https://www.motortrend.com/news/bill-fredericks-427-ford-sohc-powered-slingshot/
  27. jnaki
    jnaki
    Hello,
    When this photo appeared, everyone was amazed. It took some talent to create something so different than the T-bucket roadsters we saw on TV or at the car shows. We knew the licensing limitations for roadsters without fenders was 1500 pounds. So, more than likely, it was legal in those terms. But, for the other build techniques, simply amazing at the skill and thought in design. But, crash protection and braking since the front brakes do most of the stopping power?
    Bill Fredericks’ 427 Ford SOHC-Powered Slingshot
    upload_2024-1-1_16-4-0.png Bob D'Olivo Photographer
    There is plenty of information on the build as noted in magazines from a long time ago.
    upload_2024-1-1_16-4-48.png Despite the fact that it is/was advertised as street legal, the term is questionable. Yes, he had motorcycle inserts in the individual headers. But, for safety issues, how can a roadster without any headlights be actually legal? And, no front brakes? Yowzer! Also, talk about not being able to get into any drive-in restaurant parking lot driveway with the extremely lowered suspension, lower than most side view “Lakes pipes?” What about going to the drive-in bumps with the speaker handy? ha!
    Jnaki
    As noted, it was a cool design and drew a lot of attention. But, street legal is a term used very lightly in this case. Perhaps he owned a very long double car garage and took up both deep length spaces.
    Sharpone, deadbeat and mad mikey like this.
  28. Tim
    Tim
    from KCMO
    I know a guy with a roadster that’s got no front brakes, is lower than that thing, has headers pointed damn near where a rear view mirror might live and once in a while it has no headlights.
    put over 10,000 miles on it since March from Minneapolis to Austin and all point in between.
    streetable is all in what your willing to put up with.
    most of the rolling bones guys keep the head lights and stands in the trunk til it’s dark out. No argument that they drive those.
  29. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    But where is it today? Lost?
    Sharpone and OLE442 like this.
  30. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Re headlights: For my avatar champ car, which I plan to license, I sunk 1/2" drive sockets upside down into the frame, welded flush with the top. My headlight stanchions will be 1/2" socket extensions, dolled up to snap into the frame sockets and quickly and easily removble. headlite 37.JPG headlite 39.JPG
    Sharpone likes this.
