Technical T hood
Discussion in 'Traditional Hot Rods' started by dirt t, Apr 24, 2023.
  1. dirt t
    dirt t
    What gauge metal should I use?
    Thanks for your time.
    27 T touring model A grillshell.
  2. I used 1.5mm (around16G) aluminium. Mainly because I could get offcuts for free....
  3. 2OLD2FAST
    2OLD2FAST
    from illinois
    18-20gauge aluminum kilned steel .
    Just Gary likes this.
  4. goldmountain
    goldmountain
    Just like hotrodfil, I used free leftover aluminum. Unfortunately it was 14 gauge (I went and measured). It was too hard to bend over my knee or my oxygen tank so I used a roller at the sheet metal shop. It also tore at the corners when I louvered it. Free sometimes costs too much. Go with 20 gauge.
  5. HOTRODPRIMER
    HOTRODPRIMER
    We have made a few hoods and have found that 18 gauge seems to work best. HRP
    Atwater Mike, hrm2k and dirt t like this.
  6. alchemy
    alchemy
    I would use 18, and think 20 would be too wiggly. Especially if you aren’t rolling the edge.
    Atwater Mike and Tman like this.
  7. 2OLD2FAST
    2OLD2FAST
    from illinois
    Why would you not hem the edge on wire ?
  8. alchemy
    alchemy
    I’m not real familiar with T hoods, but the A and later Ford hoods had the front and back edges hemmed on themselves, not on a wire. Just flat over. It made them plenty firm. Did stock T hoods have a wire in the edge?
    Atwater Mike likes this.
  9. 2OLD2FAST
    2OLD2FAST
    from illinois
    I've no idea , just seems to me it would be beneficial .
  10. Atwater Mike
    Atwater Mike
    18 ga. alum. kil steel! Hemmed once-over at edges. Jack Hagamann Sr. 'recipe'.
  11. The original body would have been 20 gauge as I recall. I use 18 gauge steel a lot because it takes less stiffening bends. A lo depends on how the part is being made. Is it smooth? Will it had a lip rolled on the sides, front and or back? Will it be louvered?
    All that makes a difference.
    20 gauge is easier to work but 18 gauge makes a more substantial part.
  12. dirt t
    dirt t
    Thank you
    Terry aka dirt t
