T radiator wobble... What's your solution?
Discussion in 'The Hokey Ass Message Board' started by Dynaflash_8, Sep 18, 2013.
  1. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    So after driving this 27 t around, Iv noticed something that bothers me. The radiator flexes side to side quite a bit. Almost like a shake. I have the upper rad support hooked up, but it still shakes back and forth at idle. Heres a pic of my setup
  2. tfeverfred
    tfeverfred
    Adjust your timing.:D
  3. verde742
    verde742
    stop worry- ing hav fun..
  4. hoop
    hoop
    Made an X brace on the back of the radiator out of 3/8 or 1/2 inch round rod.Fan just cleared .Stopped the wobble. Welded to radiator frame. Worked for me.
  5. Use support rods like a Model A. They won't "bounce" as much.
  6. Tighten up your radiator bolts,,you do have springs on them don't you?
    There will be some shaking,,it's normal. HRP
  7. blackout
    blackout
    Yea they shake. I presume your lower mounts have the springs?
  8. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    No, solid on the bottom
  9. It would be wise to install the bolt springs,this keeps the radiator from shaking apart,,,never mount the radiator solid. HRP
  10. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    Ok. I'll change that out. Thank you!
