Hot Rods T touring
Discussion in 'The Hokey Ass Message Board' started by dirt t, Jan 5, 2021.
  1. dirt t
    dirt t
    Need some help, I'm building a 27 T tub and would like a single gauge cluster.
    Speedometer in the middle with the other gauges around it.
    12 volt preferred .
    Please list any you know of.
    Thank you for your time
    Terry aka dirt t
  2. This is a tough one to beat for simplicity and Vintage look if that's what your after. They are 6-V but a Runtz resister will take care of that.
    Hamtown Al likes this.
  3. jaracer
    jaracer
    I believe this is a 1950 Ford gauge cluster. I've got it in my Model A. It has an ammeter, but it is inductive so it doesn't have the potential problems of a hard wired ammeter. IMG_1378.JPG
    Hamtown Al and alfin32 like this.
  4. dirt t
    dirt t
    Jaracer, is that car or truck?
    Thank you
  5. Dman
    Dman
    Kaiser. Not 12 V but like the looks.
  6. badshifter
    badshifter
    The one Pist N Broke posted is a 51 Ford car speedo, and the one Jaracer posted is a 49-50 Ford car/wagon speedo. Both are 6 volt, but you can use either on 12 volts with a Runtz voltage reducer for each gauge, oil, fuel, and temp. The 51 Ford wagon uses the same speedo as the 49/50 cars.
    Hamtown Al and Pist-n-Broke like this.
  7. badshifter's info is spot on.
    This is the 50 Truck gauge panel.
  8. dirt t
    dirt t
    Thanks guys. I kinda like the the truck cluster.
