Hot Rods T10 and super t10
Discussion in 'The Hokey Ass Message Board' started by bangngears, Nov 24, 2014.
  1. bangngears
    bangngears
    from ofallon mo
    I am looking at a 65 Catalina that supposedly has a super t10 in it. What is the differance and how to tell from looking at the case.
  2. mgtstumpy
    mgtstumpy
    j-jock likes this.
  3. bangngears
    bangngears
    from ofallon mo
    Thank you mgtstumpy. Quite a bit of info.
  4. saltflats
    saltflats
    from Missouri
    Super T10 will have the large output shaft and spline like a turbo 400.
  5. Ebbsspeed
    Ebbsspeed
  6. The early T10s were infamous for popping out of gear when decelerating on the engine after they got a bit worn, usually 2nd gear. A redesign on the syncro ***embly for the 'Super' version cured this problem, which was backcut teeth on the gears and syncro ring. The later type syncros can be retrofitted to the early trans, although it's just about as cheap to buy a new one.
  7. Hemi325
    Hemi325
    from Boerne, TX
    I have a Super T10 with an "X" metal tag. Anybody know what that signifies?
  8. ago
    ago
    from pgh. pa.
    The very early BW T-10 had iron case from 1957 to Jan. 1961. then aluminum.Some of the later super T-10s had an iron main case. The torque of the lower 1st gears were trying to push the input gear away from the cluster gear in the aluminum case. They went to an iron main case because it is stronger than aluminum. The second design SUPER T-10 was a much stronger gearbox. Muncie stopped production in 1974.
    Ago
  9. Gene Boul
    Gene Boul
    I have a T10 with an iron case and aluminum tailshaft. The numbers are T10-1B WGD Q2 6-2
    It was in my 56 chevy that won cl*** @ the 1965 AHRA winternationals. I was 18 and my buddy and I flat towed it from Baytown Texas to Scotsdale Arizona. The engine was a 268" mouse @ 13.5 pd. per inch
