T10 ID
Discussion in 'The Hokey Ass Message Board' started by davidh73750, Nov 23, 2014.
  1. davidh73750
    davidh73750
    Looking at this trans the d2 71 makes me think April 71? Not as familiar with them. Any input appreciated. ImageUploadedByH.A.M.B.1416770241.216073.jpg ImageUploadedByH.A.M.B.1416770267.633392.jpg
  2. davidh73750
    davidh73750
    Trying to determine if it's early or later 60's early 70's
  3. squirrel
    says 1961 right there...plain as day....but that's just the side cover. How about pics of the whole transmission?
  4. davidh73750
    davidh73750
    I thought months years listed but day too?
    I was told the cast irons were likely non Chevy but other gm products? Anyone know?
  5. squirrel
    pictures.....if we can see the front of the transmission, it would be a big help. Then we can see what it bolts to, they all have different cases to match that car makers bellhousing. What is the input shaft diameter and spline count.....
    Also the letters/numbers on the case will help narrow it down.
  6. davidh73750
    davidh73750
    ImageUploadedByH.A.M.B.1416783374.419823.jpg ImageUploadedByH.A.M.B.1416783386.853213.jpg
  7. davidh73750
    davidh73750
    10 spline count.
  8. davidh73750
    davidh73750
    I haven't bought it but looking at it. Thought of putting it behind a 292-6
  9. squirrel
    co**** spline output shaft, iron case, sure looks like an early Chevy T10. Are there any numbers on the main case?
    I did find a thread on a corvette forum from about 10 years ago that lists several of the numbers.
  10. davidh73750
    davidh73750
    Found this on Hemings
    Borg Warner also released that same T-85 manual three-speed in '57. Late '50s and early '60s Corvettes used an aluminum case, while the full-size GM units from '57-'60 used a cast-iron case. GM used all aluminum-cased units after 1960, and all manufacturers used aluminum cases up until 1974.
  11. Hackman
    Hackman
    from Butte, MT
    I would say that it probably is a 61 throughout. I believe that the standard t-10 started getting aluminum tail housings in about 64 or 5. Single groove input is a standard issue gear ratio. I would guess an Impala.
  12. 3wLarry
    3wLarry
    from Owasso, Ok
    How much is he asking for it? I have a '67 Muncie M-20 wide ratio and a 1963 Borg Warner T-10 close ratio.
    kidcampbell71 likes this.
  13. davidh73750
    davidh73750
    $300
  14. 3wLarry
    3wLarry
    from Owasso, Ok
    does it come with a Hurst shifter? ;) I'm in the Tulsa area
  15. davidh73750
    davidh73750
    Nothing else
  16. stillrunners
    stillrunners
    from dallas
    open the side case and look at the gears.....nice gears - it's worth $300.....see what the builders are getting for them at the swap meets lately ?
  17. Frank the Crank
    Frank the Crank
    from So Cal
    Based on the info provided, my T-10 info identifies this as a very early Borg Warner aftermarket trans. (Aftermarket like sold at a speed shop.) Looks like a Super T-10 with a 904 nodular iron main case and it should have nickel gears. Either way it looks like a decent trans as long as the guts are in good shape.
  18. mgtstumpy
    mgtstumpy
