t5 adapters, speedway vs offenhauser
Discussion in 'The Hokey Ass Message Board' started by millersgarage, Jul 30, 2012.
  1. millersgarage
    millersgarage
    I've been looking for info on which to use. Is the Speedway just a knock off of the Offenhauser?
    Is one better than the other?
    Any and all info is appreciated.
  2. CNC-Dude
    CNC-Dude
    Everything Speedway sells is a ripoff or knock-off of someone else's hard work. Support Offenhauser.
  3. millersgarage
    millersgarage
    I was kinda thinking along those lines anyway. The photos and some reviews I have found look like the Offenhauser adapter needs to be notched out for the starter nose.
    is this true?
  4. hot-rod roadster
    hot-rod roadster
    from Omaha Ne.
    Cornhusker Rod and Custom has one of the Best kits available and Gary (owner) Krylon32 is an alliance vender.
  5. millersgarage
    millersgarage
    But cornhusker's doesn't use the original pedals and linkage.
  6. Weasel
    Weasel
  7. bobscogin
    bobscogin
    I used the Speedway adapter. No problems with it.
    Bob
  8. Mr48chev
    I bought the adapter plate that Dwight Bond sells direct from him along with the pilot bushing and shaft adapter to hook the Model A linkage to the truck Hogshead. I already had the hogshead on the back of the engine so that wasn't an issue but they are easy to find.
  9. millersgarage
    millersgarage
    This was why I couldn't find the answer doing a search on this question. Everyone tells me to buy something other than what I was asking a question about.
    Not trying to be a jerk, but I wasn't asking what was available, I was asking what the difference between these two are.
  10. millersgarage
    millersgarage
  11. denis4x4
    denis4x4
    from Colorado
    A lot of the Speedway Motors branded products are rebranded Offy items under a licensing agreement.
  12. bobscogin
    bobscogin
    I'll answer your question with this addendum to my post#7. The only difference I could see is that one has "Speedway" cast in it, the other has "Offenhauser".
    Bob
  13. Slick Willy
    Slick Willy
    When I was purchasing mine there was alot of confusion (4 years ago)
    I called Speedway and asked if theirs was cast from an Offenhauser unit. They hemmed n hawed and eventually said that it was....
    THEN she went on to say, "wait, I cant sell it to you. Our (speedway) units have been put back into research and development"
    I got frustrated, cashed in some extra cans, and ordered everything from cornhuskers.
    As far as I am concerned, the two are the same. Its sort of a pain in the ass to have to order all the parts seperately.
  14. millersgarage
    millersgarage
    :D thanks
    but I was looking for info like your first post, that you used one, and it worked fine.
  15. 40FordGuy
    40FordGuy
    A few years back, Offy was slow as molasses in January, when it came to getting things out to dealers,... After waiting almost a month,I ended up buying a bell housing with "speedway" cast into it,. and it's just fine.
    4TTRUK
  16. 40FordGuy
    40FordGuy
    millergarage.... In the case of bellhousing, NO difference.................
    4TTRUK
  17. 33Tudor
    33Tudor
    I too bought the Speedway adapter and it worked fine. For the record, I ground off the Speedway logo. Not that it made a difference, I just thought it looked cleaner without a logo.
  18. yes
  19. bought the cornhusker"kit",most of the parts were from speedway?!,the bellhousing was an offy unit with the "offy" name ground off..had to notch it when i used it with a merc mid bellhousing for starter snout clearance
  20. Tommy's Cycle
    Tommy's Cycle
    from So Cal
    I have used the Speedway adapter twice and no issues.
  21. HellsHotRods
    HellsHotRods
    Made in CHINA ???????
    That alone would cause me not to purchase it for an American Hot Rod
  22. nick_c
    nick_c
    from texas
  23. bobscogin
    bobscogin
    Where was that asserted? I missed that part of the thread.:confused:
    Bob
  24. denis4x4
    denis4x4
    from Colorado
    Since you live in SoCal, take a run up to Alhambra Blvd. and see for your self that Offy stuff is NOT made in China.
  25. The flathead adapter I bought from Speedway a couple years ago was in a Speedway box, and when I opened it up, it was marked Offenhauser...
    I haven't got quite that far in the build, but I did a test fit and it seemed to fit pretty good into the bell housing and matched up with the mounting holes in the T-5...
  26. HellsHotRods
    HellsHotRods
    I never said it was...hence the question marks on the end. I'm actually wondering if the Speedway adapter is made in China.,,, it wouldn't surprise me
  27. Weasel
    Weasel
    If you had clicked the V8 sidebar right below Model A & B sidebar you would have seen their adapters also available for flatheads....
    www.macsspeed.com/adapters_2.html
  28. Okie Pete
    Okie Pete
    Make your own . That i did. Hell we are Hotrodders.
  29. bobscogin
    bobscogin
    Well, if the Speedway part is made in China, it's proof that the Chinese can make a quality part. However, I don't think it's of Chinese origin.
    Bob
  30. bobscogin
    bobscogin
    I think most of us here do that, but just because you can doesn't mean you should. I buy many of the parts that I could build. The amount of time I can allocate to a project has to be weighed against the price of the part, so I buy what's readily available at a reasonable price and fabricate what I can't buy. I guess I could buy a variety of hex stock and machine my own nuts -- or not.:rolleyes:
    Bob
