t5 chev transmissioin
Discussion in 'The Hokey Ass Message Board' started by truckrick, Jan 7, 2014.
  1. how to install chevrolet t5 transmission with speedway adaptor into a 1935 ford:confused:
  2. help with frame clearance should original tranny mounts be removed and frame trimmed to allow fit of chevrolet t5
  3. Seems you would have to place eng&trans to see where to cut
    or modify.Also how will pedals mount?
  4. Pewsplace
    Pewsplace
    Several How To's on here. The T5 is a common installation and requires a little modification but not much. Do a search.
  5. johnny bondo
    johnny bondo
    from illinois
    after you cut the nose cone down on the trans and drill the mounting holes to 1/2 inch, you remove the middle of the X member on the frame, and then install the speedway wishbone mount/trans mount for 35 ford. you then take the stupid stock shifter arm off, put a 1 inch spacer under the shifter. take the shift arm assembly apart and then move the pivot shaft up one inch, weld on the 35 shifter arm. make the driveshaft.
  6. dumb question but what is the nose cone and how much do you trim truckrick
  7. brokenspoke
    brokenspoke
    The search function is your friend....( T-5 Tech) try it
  8. chinarus
    chinarus
    from Georgia
    I read all 14 pages of T5 posting "Ultimate T-5 Article" and only found 1 reference to trimming the nose cone (page 5 "I'm thinking about putting the T-5 behind a 283 V8").
    For a flathead, the common adapters which use the ford crosshaft arm and stock throwout bearing doesn't appear to require a nosecone modification based on reading the Speedway help doc or other internet articles I have found.
    A special pilot bearing and a clutch that eliminates flywheel bolt interference seems to be the the biggest difference from stock components other than the engine/trans adapters for a flathead T5 setup.(http://www.flatheadv8.org/t5-swap.htm)
    Is nosecone trimming required for some specific T5 models like the later WC or it depends on the throwout bearing setup and engine/flywheel?
    The T-5 Tech URL:
    http://www.jalopyjournal.com/forum/showthread.php?t=171291&highlight=t5+tech
  9. johnny bondo
    johnny bondo
    from illinois
    im talking about the cone that holds the front seal and bearing in, that the throwout bearing rides on. i also vaguely remember pressing a sleeve over it
    im not sure if it is for the fords or the chevys tho been a while.
