Hot Rods T5 help!
Discussion in 'The Hokey Ass Message Board' started by chevytruckfan, Feb 26, 2012.
  1. chevytruckfan
    chevytruckfan
    from Mesa, AZ
    I just installed a WC T5 behind a 292 stock inline 6. I can't ge the clutch to work right. It is not engaging correctly. Everything went together like it was supposed to. I can put the truck in gear, start it up and it wants to go. If I start it up in nuetral, it will not go into any gear, it wants to but the clutch is no engaging far enough to get it into gear. I have adjusted the new clutch rod almost as far as it will go. It doesn't seem to make a dfference.All new parts, clutch disk is new, arm, throw out bearing, pressure plate, everything. help!
  2. Window Licker
    Window Licker
    it sounds like you need to make the clutch disengage more, meaning you need the throw out bearing to move closer to the motor. without seeing it i dont know which way to adjust the rod that depends on how you have it set up. A picture of your set up will get you a lot more help.
  3. brokenspoke
    brokenspoke
    Did you make the needed modifications to the trans?
  4. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
  5. Flat Ernie
    Flat Ernie
    Tech Editor
    As I mentioned in thread above, this is often an issue with the S10 version on the T5. The S10 T5 input shaft is longer than the standard Chevy input shaft all the adapters are made for...
