1952-59 Ford t5 in a 52
Discussion in 'Off Topic Hot Rods & Customs' started by raybug, Jan 10, 2012.
  1. raybug
    raybug
    hello has anyone put a t5 in a 52 or 53 ford and if so what all is involved thanks
  2. FlatHat
    FlatHat
    Do you already have the T5? What year and model is your car? I put one in my '53 Victoria, and it turned out great. You'll get a lot of opinions about the swap here. You can spend a ton of money on expensive parts and pieces, or you can do it for a lot less.
    In my installation I used:
    • the stock bellhousing
    • the stock flywheel
    • the stock pressure plate
    • the stock pilot bearing
    • the stock throwout bearing
    • the stock clutch linkage
    • the stock '53 rear transmission mount (modified).
    You'll need:
    • a simple adapter plate
    • a different clutch disk
    • a different speedometer cable
    • a new driveshaft and front yoke.
    The MOST important thing is choose the T5 carefully; there are three basic shifter locations and several different gear sets.
  3. SUCIO
    SUCIO
    Im interested in whats involved with this swap as well. Looking forward to the info.
  4. JeffB2
    JeffB2
    from Phoenix,AZ
  5. raybug
    raybug
    thanks flathat i aready a 302 and a auto trans in it but i want to put a t5 in it so i bought a 90 model mustang trans ive got the trans, bellhousing cluth,pressure and bearing my 52 customline was a stickshift so yhe pedal is still there thanks ray
  6. FlatHat
    FlatHat
    What rear end will you be using?
    Does your T5 have an electronic speedometer sender?
  7. raybug
    raybug
    i have a 8 inch maverick rearend and electric speedo
