Technical T5 in a Shooebox
Discussion in 'Traditional Customs' started by Chop50, Oct 1, 2022.
  1. Chop50
    Chop50
    Hi All,
    Anyone out there have experience with T5 trans in a Shoebox? What is needed..
    Thanks, Steve
  2. gimpyshotrods
    gimpyshotrods
    What engine?
    X38 likes this.
  3. Chop50
    Chop50
    Right now H-226 flathead 6, in the process of building Mercury flathead V8.
  4. bobss396
    bobss396
    Speedway has or had a T5 kit to go with the flattie V8. You should read the reviews on it before shelling out any $$$.
  5. Chop50
    Chop50
    Yeah, I was kind of looking for an
    Offenhauser. Wondering if it works with 8BA as well as 59A
  6. pprather
    pprather
    gimpyshotrods and caprockfabshop like this.
  7. caprockfabshop
    caprockfabshop
    gimpyshotrods likes this.
  8. Steve, Krylon has a complete kit. Cornhusker Rod and Custom, 1-407-749-1932. nick
  9. Mr48chev
    Ford T 5 or a Chevy T-5 ?
    Cornhuskers kit and the Speedway knockoff of his kit use the early Ford clutch fork setup that has the shaft that the pedal turns. Speedway does have an adapter setup for a hydraulic clutch but that opens another can of worms as far as easy swap.
    This plate Bolts a Shoebox steel bellhousing right up to a Ford T-5 49-53/52-53 Ford Flathead to Ford T5 Adapter plate - Modern Driveline Less jacking around and a lot simpler.
    You may want to swap tail shaft to an S-10 Tail shaft to move the shifter forward As the Ford Shifter will be right back at or in the seat.
    RICH B likes this.
  10. Chop50
    Chop50
    Nick,
    Spoke with Cornhusker today, they only make kits for the earlier blocks not 8BA. Speed Gems has just the ticket though. Need to find a Camaro or Firebird trans.
    Steve
    pprather likes this.
  11. enjenjo
    enjenjo
    from swanton oh
    You will be happier with an S10 T5. Better first gear ratio for an 8BA
  12. gimpyshotrods
    gimpyshotrods
    There are two different ratio sets found in S10 T5s.
    One has a 3.76:1 first gear, the other a 4.03:1 first gear.
  13. gimpyshotrods
    gimpyshotrods
    There are reproduction S10 T5 tail housings out there. I have used them with success. S10 shift rails are easy to get.
    A guy on eBay has a speedometer gear relocation kit, so that will work, too.
    Atwater Mike likes this.
  14. Dan1982
    Dan1982
    does the t5 swap in the shoebox require any modifications to the transmission cross member?
  15. gimpyshotrods
    gimpyshotrods
    Yes, you will need to modify the crossmember, or make a new one.
    Dan1982 likes this.
  16. Dan1982
    Dan1982
