T5 mods
Discussion in 'Off Topic Hot Rods & Customs' started by Rally 1, Jun 25, 2025.
  1. Rally 1
    Rally 1
    Currently running an S10 trans, 4.03 low gear, in my banger powered coupe.
    First gear is pretty much useless. Can other gear sets be installed in the S10 case, would like the 2.95 Camaro gear set.
    Thanks
    Ken
  2. winduptoy
    winduptoy
    The short answer is 'yes' and have a buddy that changed one up for his banger powered ride. The revision took a main cluster shaft change. As I recall, because of that, it changed the 5th gear overdrive ratio. By the time he got it done, he wished he had just hunted for a complete transmission that already had the gear sets he wanted.....but that transmission might come with its own set of problems....
    I don't recall all the details...I've texted him for additional information but he checks his texts every week or so. and doesn't answer his phone...
    I don't know what you have for a rear differential ratio, 4.11 or 3.78...that makes a difference too
    I run a taller tire and a 3:54 rear gear in my T-5 Jeep transmission in my banger powered Vicky. It has a 4.03 first gear and it helps the driveability and allows me to creep up my driveway that has a 18% climb in it at one point....but it sure can make 5th OD too tall with an uphill and headwind
    banger power, the most money you can spend to go slow....but you never break anything by overpowering it
    good luck on your pondering
  3. gimpyshotrods
    gimpyshotrods
    Not exactly. Changing gear sets means changing the input shaft, too, because it interfaces the counter shaft.
    Only S10's have an input shaft that length (the longest of all). Your one common choice is the 3.76 S10 gear set.
    There are 2 (I think) other ratio sets, but are not at all common.
    1oldtimer likes this.
  4. wuga
    wuga
    Maybe more info on the banger. Lightened flywheel? Rear gear? 4X4 or long tail shaft t5? Mods to the engine? All of the above impact on gearing. I am running a fairly healthy motor in my banger with a Burtz 30lb flywheel and a 4:03 Jeep t5, closed drive shaft and 3:78 rear gear. I love the combination. Great acceleration, easy on inclines and still keeps up at highway speed. I personally don't think you would like the 2:95 behind a banger motor. I have a 2:95 in both my '62 Cutl*** and '62 Studebaker wagon, both with quite warm engines and there are times they would like a little more gear.
    Warren
  5. krylon32
    krylon32
    from Nebraska
    All the rebuilt T5's we sell have the 3.76 first gear and .72 OD. Have done a couple 100 over the years with minimal problems or complaints.
    gimpyshotrods likes this.
  6. brigrat
    brigrat
    from Wa.St.
    Buy the rite 5 speed sell yours, less heartache...............................
    Deuces and Tow Truck Tom like this.
  7. Rally 1
    Rally 1
    The engine is very healthy, 8:1 compression, big cam, two strombergs, etc. lightweight flywheel. Open driveshaft. I’ve been considering changing rear axle to a 3:54, currently 3.78
    Then , the option of a quickchange is there as well, depending on budget.
    Thanks for the feedback….
    Keanu
  8. gimpyshotrods
    gimpyshotrods
    The thing to focus on is the combined starting ratio, which is the first gear ratio x the rear end ratio.
    Your current starting ratio is 4.03 x 3.78, or 15.23.
    If you went to the other common S10 set, it would be 3.76 x 3.78, or 14.21*.
    If the Camaro set were possible, it would be 2.95 x 3.78, or 11.15. That would likely be terrible.
    With a 3.54 rear and your current transmission, it would be 4.03 x 3.54, or 14.27*.
    A 3.76 gear set and a 3.54 rear, it would be 3.76 x 3.54, or 13.31.
    *These two would likely be indistinguishable. Two pathways to get to just about the same result.
    Another alternative is a taller rear tire. What are your running now?
    winduptoy, indyjps and Tow Truck Tom like this.
  9. DDDenny
    T-10's are traditional!
  10. wuga
    wuga
    Actually, in 1961, a '55 Chev 3 speed was traditional behind a 265. Never was a flathead guy. 4 speeds didn't become affordable to back yard builder for quite some time. A T10 would have cost me more then it cost to build the hot rod.
    Warren
  11. gimpyshotrods
    gimpyshotrods
    So is Polio.
  12. That is what I tell myself as I slowly get my 283 and T5 ready to go in my A pickup
  13. Rally 1
    Rally 1
    Rear tire size is 7.60-16
    The oem trans has a 3.12 first, acceptable, first gear 11.79 overall
    Looks like the quickchange is in the future.
