T5 question
Discussion in 'The Hokey Ass Message Board' started by Judd, Mar 15, 2006.
  1. Judd
    Judd
    How strong is a T5 from a 94 Mustang HO? How does it compare to the top cover Ford 4 speed fron say a 66 Mustang or a 66 390GT Fairlane? Will it grind into dust the first time I really give it all a supercharged 302 with 4.30 locker and smaller slicks has to give like a smallblock Ford T10 would?
    Thanks.
  2. Model40-770
    Model40-770
    from LOUISIANA
    In my experience it is fairly close to t10 in strength.......with the slicks and supercharger don't expect it to live a long happy life...............
  3. Scripts
    Scripts
    Id say to go with the TKO-500 or 600. The 500 will withstand 500 ft/lbs of torque and the 600 will handle 6. They will also fit in any spot that a T-5 will Perfectly. A good source is Dark Horse Performance.
  4. Judd
    Judd
    Thanks y'all, I was afraid of that. Kid gloves till I can spend 2K on a*******. LOL
  5. AlbuqF-1
    AlbuqF-1
    from NM
    More work to fit it, but a T56 6-sp is not much more than the TKO....very strong
  6. Flat Ernie
    Flat Ernie
    Tech Editor
    Also, bear in mind you need a '94-95 bellhousing or put a '91-93 input shaft in that******* - the '94-95 T5 has a 3/4" longer input shaft to accomodate the re-design of the SN-95 platform over the earlier Fox platform & they changed both the bellhousing & the input shaft...
    Having said that, check on the late-model Mustang websites like corral.net or saleen.com (if they're still around) - plenty of folks are running supercharged stroker engines with the T5 behind 'em. A good aftermarket shifter with positive stops goes a long way to keeping these*******s alive.
    The next concern is how heavy is the car & how much hook-up do you think you're going to get...if you're still going to spin your slicks (ie - traction limited), it'll probably live...they're not made of glass.
