T5 rebuild/upgrade kit
Discussion in 'The Hokey Ass Message Board' started by adventurer, Sep 4, 2011.
  1. adventurer
    adventurer
    Was trying the 32 roadster on the dragstrip yesterday,and the T5 behind my 325 Hemi Dodge just broke....reverse will not engage, and 5th just started to do the same. Besides, it's very noisy at idle. Guess the Hemi is too strong for this trans. Since car has just been finished, I am not in the mood to modify the car to adapt a better trans, so will have to use what I have. Is there someone specialized in this trans that can get me the parts to modify and improve it? The T5 is out of some Ford, don't have an idea where it comes from, bought off ebay a couple of years ago. The engine is really strong, and need the engine rebuilt to handle the torque of the Hemi.
    Thank you
  2. seb fontana
    seb fontana
    from ct
  3. adventurer
    adventurer
    Thank you....any other input?
  4. sstang06
    sstang06
  5. 32SEDAN
    32SEDAN
    Flathead Ernie is the MAN on this subject - hopefully he'll chime in
  6. spiderdeville
    spiderdeville
    from BOGOTA,NJ
    maybe a world cl*** up grade ? maybe a DNE 5 speed
  7. D-Russ
    D-Russ
    Can a NWC be upgraded to a WC by simply installing WC internals?
  8. johnboy13
    johnboy13
    No, they're too different.
  9. Jmountainjr
    Jmountainjr
    G-Force or Hanlon have upgrades to make a pretty stout T5.
  10. I had Hanlon rework my 3550 and they do really good work and are fair people.
  11. Shizzelbamsnapper
    Shizzelbamsnapper
    from Ohio
    Yes, done it many times. You will need EVERYthing out of the WC except the case. It can be done.
    If Reverse and 5th won't engage it probably a problem with that shift rail, since it operates both. If it grinds going into reverse its the pilot bearing, its gulled on the input shaft causing the whole gear set to spin at idle speed and not letting it slow down for engagement.
  12. Shizzelbamsnapper
    Shizzelbamsnapper
    from Ohio
    The only difference is the mainshaft and gear ratios, it can be done. We do it all the time for Chevy owners who want a T-5 with the old Chevy bolt pattern on the bell housing. Now is it cost effective? That depends on how bad you want a WC in a NWC case, but it can be done.
  13. 61falcon
    61falcon
    my world cl*** t5 is holding up well behind my 331 stroker. it has been in there for 6 years now with alot of 1/4 mile p***es and some street abuse as well.
