1952-59 Ford T5 Seat clearence
Discussion in 'Off Topic Hot Rods & Customs' started by Oldskoolbelair, Jun 4, 2011.
  1. Oldskoolbelair
    Oldskoolbelair
    Hey guys I am getting ready to buy a t5 for my 302 that will eventually make it into my 53 victoria. Before i go an hand over the money for it. I was wondering if anyone has had any clearence issues with the shifter an bench seat.
  2. FlatHat
    FlatHat
    My '53 has a flathead in front of a T5, so this may not apply perfectly. I spent a lot of time measuring stuff on various T5 versions and then mocking up shifters in order to arrive at the optimum stick position.
    The S10 shifter was too far forward and would require a long shift lever. The longer the shift lever, the longer the throw between gears.
    The Mustang T5 put the shifter virtually under the edge of the front seat; not good, either.
    I found the best approach was to use an AstroVan main case which has the shifter about halfway between the S10's and the Mustang's shifters. It worked out perfectly. A basic S10 shifter mechanism bolts right to the AstroVan case.
    AstroVan cases are scarce, but you can find one. Doing it that way, you can install any gear set you want inside the AstroVan case. I'm using a 2.95 gear set which is great with the 4.10 rear end.
    I have lots of pictures if they would help.
  3. hotroddinkc
    hotroddinkc
    i put a 302 and t5 in my 55 customline and used the lokar double bend shifter. worked perfectly and cleared the seat. my t5 came out of a 91 mustang gt
  4. Oldskoolbelair
    Oldskoolbelair
    cool! thanks for the info. i was thinking it would be close. how did you guys do the clutch?
  5. FlatHat
    FlatHat
    Hope this picture gets through. This is the shifter on the AstroVan main case of my T5 in my '53 Victoria. Cross your fingers.
  6. FlatHat
    FlatHat
    "How did you guys do the clutch?"
    I used my stock flywheel, stock pilot bearing, stock throwout bearing, stock pressure plate, stock linkage, and a new disk to match the splines on my T5's Ford input shaft. Everything works like a charm.
  7. Oldskoolbelair
    Oldskoolbelair
    FlatHat that looks good! I am going to call around monday an see if i can find that astrovan case.
  8. FlatHat
    FlatHat
    If you can't find one locally, try these guys. They built mine to my specifications. They ship all over the world.
    Astro Performance
    601 East Alfred Street
    Tavares, Florida 32778
    (866) 253-0019
  9. Oldskoolbelair
    Oldskoolbelair
    okay cool! I will thanks!
  10. FlatHat
    FlatHat
    They are absolutely super folks and helped me enormously throughout my entire installation process. I'm lucky enough to be ten minutes from them! Not only that, but they stand behind what they make and sell.
