T5 Speedometer Cable
Discussion in 'The Hokey Ass Message Board' started by DirtyDave, Jan 31, 2013.
  1. DirtyDave
    DirtyDave
    I have read practically every thread looking for what would seem to be an easy question. I need a speedometer cable that connects a Ford Mustang T5 to an aftermarket speedo. Appreciate the help.
  2. AREA51SD
    AREA51SD
    It depends on your aftermarket gauge end, but a regular Ford 3 speed or c-4 speedo cable will work or you can use a lokar kit SP-1502U (Black) or SP-1503HT (stainless). You might have to get a adapter from the manufacture of the gauge to make it work and also might want to change the speedo gear in the trans to get the right MPH.
  3. DirtyDave
    DirtyDave
    Thanks
    I clearly need to do more research on which year ****** I have. The speedo output pictured is nothing like the cable I hold. May be later year electronic. HAMB 7.jpg
  4. e1956v
    e1956v
    Alliance Vendor
    Looks to me that you have half of a broken speed sensor still in the trans, pull it out and you will find the speedometer driven gear held on with a clip. The bottom fitting is a standard Ford with a clip on gear that is crimped on the end of the speedometer housing, if you are using an after market speedometer the nut on the speedo end is 5/8-18. If you need a cable and housing made give me a length and what speedometer you are using and we can make one up for you. Or get one from a 1968 or older Ford car or truck that is the right length. Hope this helps.
  5. earlymopar
    earlymopar
    Helpful post. I am or will be facing a similar situation although going from a T-5 to a mid 60's Dodge speedometer.
    - EM
