T5 Tailhousing not fitting
Discussion in 'The Hokey Ass Message Board' started by brpowel4, Feb 12, 2009.
  1. brpowel4
    brpowel4
    I have a 92 Ford T5 that i'm trying to mate with a S10 electric tailhousing. I was reading the "How To" and thought this would be easy.
    My 5th gear assembly looks different than what i've seen in the "How To". The sleeve i'm pointing at on the 5th gear assembly is hitting the lip (see finger) where the funnel goes in the tailhouse. it protudes too much. I took measurements and this appears to be causing the problem. See pictures...
    Is this assembled correctly? I was thinking i could shave that sleeve down about 3-4 mm to get it to work. Or should i shave the tailhousing lip? Will this cause any problems? Thoughts?
    Bryan
  2. Flat Ernie
    Flat Ernie
    Tech Editor
    Often, this type of "problem" is simply the assembler not holding his mouth right...
    It really is quite a "fiddly" section of assembly - getting everything to line up perfectly with shafts going into different holes, etc.
    First suggestion - make sure you're assembling the trans vertically - input shaft down.. Then just keep trying and wiggling - I've seen trannys that were assembled together not want to go back together!!
  3. brpowel4
    brpowel4
    i'm using the bellhousing to stand the t5 upright and wiggled.
    However, i measured, with a framing square, how far the that sleeve i'm pointing at was from the mounting surface of the gearbox. it was 3 1/8". I then measured how deep the tailhousing is from its mounting surface to where the sleeve sits. it was 3". so, the tailhousing is an 1/8" too shallow for the 5th gear assembly (with that sleeve). The original tailhousing was 3 1/8" deep at the same location.
    the outer syncho it pretty wobbly so that's why i asked if it was assembled correctly. The transmission was just rebuilt (not by me).
    Bryan
  4. Flat Ernie
    Flat Ernie
    Tech Editor
    I'm at a loss to explain the 1/8" difference...
