Technical T5 to 350 with mechanical clutch
Discussion in 'The Hokey Ass Message Board' started by Spanky65, Feb 9, 2015.
  1. sunbeam
    sunbeam
    For a truck you might think about a nv 3500 from a pickup.
  2. gimpyshotrods
    gimpyshotrods
    The T56 has the same gear-spread as a lot of T5's, contrary to popular belief.
    It just has more stops in that spread, with a much better spacing.
    They do, however, require a different rear end ratio, to make everything equal.
  3. Budget36
    Budget36
    I was more thinking of the torque rating, gotta be a reason GM only put the T5's behind the 305's, and not the 350's.
  4. gimpyshotrods
    gimpyshotrods
    True, but then he'd be looking at a rear gear change, too.
    I'm about to swap out an S10 T5, with a 3.76-0.72:1 ge****t, for a T56, with a 2.66-0.50:1 ge****t.
    To keep things equal, the rear gear is going from 3.55:1, to a wopping 5:13:1.
    Combined ratios:
    3.76 x 3.55 = 13.348
    2.66 x 5.13 = 13.646
    0.72 x 3.55 = 2.556
    0.50 x 5.13 = 2.565
    First gear ends up being a teensy bit lower. Top gear, very close to equal.
  5. Budget36
    Budget36
    Good point, I didn't realize the T56 had such a tall first gear compared to the T5.
  6. Montana1
    Montana1
    What kind of HP and TQ are you running?
    T-5's are kinda light weights in the torque catagory unless you put an Astro Performance gear set and tailshaft in them. Then they'll take about 400-450 ft/lbs. in a light weight car.
    I broke a couple of them NWC's before I put in a WC with Astro Performance gears. Tony will take good care of you! http://www.astroperformance.com/about_us.php
    If you go beefing on it in a 3500 lb. truck and it hooks up, you might be in for a surprise.
