Technical T5 to Flathead V8 experts-need some help
Discussion in 'Traditional Customs' started by MR K., Jan 4, 2026.
  1. MR K.
    MR K.
    hi all. I need help identifying if this will work for a flathead V8 set up. Will this work? the input shaft is .590 I was told its for a 4 cylinder application??
  2. MR K.
    MR K.
    This looks to be a chevy version if I am thinking correctly
  3. alchemy
    alchemy
    It has the Ford bolt pattern to the bellhousing. If you want it to have the shifter in front of the seat, that trans might not work.
  4. MR K.
    MR K.
    10-4 thanks!
  5. krylon32
    krylon32
    from Nebraska
    Been selling T5 to Flathead engine transmission kits since 1994. Most complete kit on the market. Costs a little more to have a good one. In stock for early Chevy pattern (85-92) & late Ford (93 up) pattern trans. Gary at Cornhusker Rod & Custom
  6. Mr48chev
    Looks like a Ford trans that has had a Jeep input shaft swapped into it. That lets you run a 1o spline clutch disk rather than hunt hither and yon for the unobtainable clutch disk with the right spline and diameter.
    I wouldn't argue against it being a 2 wheel drive Jeep trans though. You would get tarred and feathered and run out of town with a two wheel drive Jeep anything around here but in some areas they seem to sell. The Novak Guide to the Borg-Warner T4 & T5 Transmissions
    If the ID tag is still on it you can usually ID a T-5 here Identification Key to Borg-Warner T5 transmission ID Tags
    ekimneirbo likes this.
  7. 50 Merc Man
    50 Merc Man
    It works, I’m running that same setup in my Merc right now, mine came out of a mid 80’s Chevy S-10, so I was told.
  8. 50 Merc Man
    50 Merc Man
  9. Ziggster
    Ziggster
  10. Looks like the same one I have in my Model A, '89 Mustang. I swapped the tailshaft with an S10 to move the shifter.
    Outback and Ziggster like this.
  11. tjm73
    tjm73
    How difficult was this swap to do?
