T5 trannsmission mount
Discussion in 'The Hokey Ass Message Board' started by harleynut45, Feb 11, 2014.
  1. harleynut45
    harleynut45
    I was wondering if anyone makes a cross member to install a T5 in a 49 F1 pickup. After reading 31Vickeys rant I'm not sure if I even want one from a supplier. Might be better off to fabricate. Any thoughts on this or a picture of one would be greatly appreciated.
  2. Jalopy Joker
    Jalopy Joker
  3. Bugsy
    Bugsy
    from Kansas
    I'm wondering the same thing. Just got my mits on a '48 F1 and a T-5 ....
  4. fastcar1953
    fastcar1953
    easy to make. get it in then see what it needs.
  5. RMR&C
    RMR&C
    from NW Montana
    What engine are you running? If you are removing the original F-1 X member, you need to replace it with a petty stout one as it provides support for the cab mounts and running boards as well. I built my own...
  6. I thought there was a link to a F1/F100 message board on how a guy installed a T5 in his F1?? I thought I saw it on here about a week or two ago? someone here must have the link?
  7. www.secondchancegarage.com
    Under projects section on the left menu, guy installs a T5 in a '52 F1
    It's on the second page, (1952 ford truck restoration part 2-Jumping in)outlines the install
    Hope this helps....
  8. harleynut45
    harleynut45
    thanks Prime....I'll look it up
  9. Flat Ernie
    Flat Ernie
    Tech Editor
    Pretty easy to fabricate....
  10. Beau
    Beau
    I did this. Easy and it allows for adjustment if needed. I'm still using the stock F1 mount. You could drop it further down if needed.
    Now that I see the link provided it really won't help you much. Looks like you need lots of clearance.
  11. harleynut45
    harleynut45
    Thanks guys for the replies and pics. My truck is totally stock as far as the drive train goes. I know that the cross member is a important part of the frame.....that being said I'll have build it strong and removable.
