T5 TRANSMISSION S10 BORG WARNER MANUAL 5 SPEED T-5 S-10
Discussion in 'Parts For Sale' started by brsturges, Nov 30, 2025 at 6:31 PM.
  1. brsturges
    brsturges
    from Miami, FL
    City: Miami
    State: Florida
    Price: 750
    Up for sale is a very nice S10 T5 transmission with the perfect shifter position for an early Ford hot rod . This transmission number is 1352-193, out of an 1989 S10. This is the non- World Cl*** version. This transmission bench shifts smoothly and feels good in all gears. Endplay feels good.
    As most of you know, the S10 trans is perfect for a hot rod since it has the shifter close to the bellhousing and works well with a bench seat. It also can be easily adapted to use with a small block Chevy or even a Flathead Ford. This S10 ****** has following ratios that I verified by putting it in gear and turning it on the bench.
    1st: 4.03
    2nd: 2.37
    3rd: 1.49
    4th: 1.00
    5th: .86
    The T5s are very light and compact so they fit in most applications. It bolts right up to a small block chevy with the standard chevy bellhousing. May need a little trim of the input shaft depending on the application. Perfect for a Flathead Ford. These T5s are becoming harder to find. I will ship on buyer's dime, which will run about $160.
    I have also rebuilt a number of these for fellow HAMBers. I can rebuild this one for an additional charge if needed.
    Feel free to contact me with any questions you may have.
