Technical T5 Transmission
Discussion in 'Traditional Hot Rods' started by jimmysweden, Jan 3, 2019.
  1. jimmysweden
    jimmysweden
    from sweden
    Any ideas? Everything except the T5 is new...
  2. squirrel
    try putting the video on youtube, instead of facebook...then maybe we could see it.
  3. KoolKat-57
    KoolKat-57
    from Dublin, OH
    Not all of us do facebook,
    KK
    Hnstray and dirty old man like this.
  4. Mr48chev
    Contents not available is what it says anyhow.
  5. 97
    97
    Farcebook! :cool:
  6. Kiwi 4d
    Kiwi 4d
    No “Stalk book” for me thanks
    97 and Hnstray like this.
  7. Kerrynzl
    Kerrynzl
    Twofacedbook [​IMG]
    Hnstray likes this.
  8. Have you checked the clutch adjustment?
    Hard to tell from the video what exactly is happening.
    There different input shafts on T5s. Are you sure the one you have matches the rest of your application? Is it ling enough to fully seat? Seems like it is jumping teeth when you let the clutch out... or something isnt bolted down tight.
    When I was adjusting the grab point on my T4 if I loosened the pedal travel to much the clutch/throw out arm/bearing assembly would knock pretty bad until I took up the slop in the pedal.
    Chappy
  9. Mike51Merc
    Mike51Merc
    I'd blame the clutch/flywheel. Hotspots, warpage, broken disc.....
  10. Clutch issues
    What engine, bellhousing, clutch, pressure plate, flywheel,clutch fork , clutch pedal, master/slave, cable , pilot bushing/bearing are you using?
    Definitely in the clutch set up/system.
    What year T5 ? And what was it out of?
    Look up “ ultimate T5 thread” here on the Hamb tons of info on T5’s
