T5 Transmission
Discussion in 'The Hokey Ass Message Board' started by RoadWarrior13, Oct 19, 2009.
  1. RoadWarrior13
    RoadWarrior13
    from Louisiana
    What years, makes, and models should i look for in order to find this ****** . I am going to the pick and pull to search for one this weekend.
  2. krylon32
    krylon32
    from Nebraska
    Depends on what you are doing with it.
  3. RoadWarrior13
    RoadWarrior13
    from Louisiana
    i am bolting it up to my 53 Flatty in my 1930 Pickup
  4. fab32
    fab32
    One out of an S-10 Blazer should fill the bill. A bonus would be that the shifter would be in the right place.
    Frank
  5. Search is your friend, this is a topic that's been covered here quite a few times.
  6. lrs30
    lrs30
    from Kentucky
    Pre-93 and out of an S-10 pick-up .. S-10 T-5 has the shifter in the right position and pre-93 is mechanical speedo...YES Blazer will work too..
  7. Flat Ernie
    Flat Ernie
    Tech Editor
    Well, from 89-91, you could get find either mech or elect speedo. After 91, all I've seen are elect.
    For the original post: Check the tech archives - click the red link in my signature line below.
  8. Irish Dan
    Irish Dan
    Go with the mechanical speedo if you can. You'll be glad you did!
  9. Hotrod95
    Hotrod95
    My dads 68 mustang has one, im not sure that it came in it though
  10. RoadWarrior13
    RoadWarrior13
    from Louisiana
    will this ****** have the least amount of problems installing ?
  11. brokenspoke
    brokenspoke
    I think your gonna have a problem....if you cant do a search (T-5 tech)
  12. bobscogin
    bobscogin
    Actually, no T5 will have the least amount of problems installing. The award in that category goes to the original transmission.
    Bob
  13. GreenMonster
    GreenMonster
  14. RoadWarrior13
    RoadWarrior13
    from Louisiana
    GreenMonster Thanks for the help...
  15. RoadWarrior13
    RoadWarrior13
    from Louisiana
  16. Dragons
    Dragons
    from Topock,AZ
    Lol, it didn't.
  17. M.Edell
    M.Edell
    I have one in my 34 Ford, right now its behind a small block chevy but soon to be behind a 392 Hemi!
  18. Hnstray
    Hnstray
    from Quincy, IL
    There is a website "BritishV8" that has a very comprehensive list of T-5's and there specifications, applications and the code used for each........an invaluable tool when looking for a T-5
  19. The October, 2006 issue of Rod and Custom has a really good article that covers the ins and outs of adapting the T-5 to vintage engines and the year and model differences.
  20. bloodyjack
    bloodyjack
    S10 4x4 back to torque tube
  21. onlychevrolets
    onlychevrolets
    a T-5 from a four cylinder S-10 will work. They have a lower first gear , I have one behind my nailhead and it's been there for a year now.
  22. Flat Ernie
    Flat Ernie
    Tech Editor
    Not if it's newer than '87. The lower first gear is based on year, more than engine. You MUST decode the tag against a comprehensive list to determine the gear ratios. You cannot go on application alone.
  23. Nice job! Got one behind my 312 also, Love it 2500rpm = 70mph with 3.50:1 rear. :)
  24. RoadWarrior13
    RoadWarrior13
    from Louisiana
  25. Fedman
    Fedman
    I'm gathering parts right now to put a t5 behind my 322" Nailhead.
    Would you share your clutch combination?
    Thanks in advance.
  26. onlychevrolets
    onlychevrolets
    Stock nailhead bellhousing, machined the center hole to fit the T-5 front bearing retainer, used a nailhead pressure plate and a S-10 disc. cut 1/4 inch off the input shaft and also the bearing retainer where the throw out bearings slides ( because it touched the pressure plate . Built a pilot bearing by turning down a chevrolet pilot untill it would press inside the Buick ( Buick had a BIG center hole ) then locked to two together by drilling a 3/16" hole from the outside edge straight toward the center hole , BUT not all the way , then I taped it 1/4 -20 and screwed in a bolt and cut the head off. Then installed it in the Buick crank. I've put over 12,000 miles on it and it works like a dream. I hope you understand what I was trying to say. If you need any other help call me at work M-F 6:30AM to 5:00PM @ I'll PM you the number
  27. Fedman
    Fedman
    Exactly the info I was hoping to find!
    Thanks a ton for sharing it. [​IMG]
  28. aldixie
    aldixie
    I got mine from a 94 S10. My local pick a part sells them for $120.
  29. junkyardgenius
    junkyardgenius
    from Kernow
    I just bolted one up to a 354Hemi.Just wondered what tail section you used, my shifter is at the rear of the box (S10 parts are a bit scarce over here) Got any pics showing the shifter in the car?
  30. Timberbeast
    Timberbeast
