1952-59 Ford T85 input shaft
Discussion in 'Off Topic Hot Rods & Customs' started by 56longroof, Sep 25, 2015.
  1. 56longroof
    56longroof
    I have found a T85 that came out of a 62 ford car. Is the input shaft the same 10 spline as the T86 I have in my 56? I just bought a new clutch and wanted to make sure it's the same before I buy the trans.
  2. Mark T
    Mark T
    I know that the T85 came with 2 different spline counts, until 1957 it had a 10 spline input. After that I'm not sure if they were all the fine spline or not.
    The T86 used a 10 spline input but I believe it was 1'' and the T85 was 1 1/16'' or 1 1/8''
    Simple solution is to change the clutch disc.
  3. TKEBH964
    TKEBH964
    from MO
    58-62 used 23 spline
