1952-59 Ford T85 Overdrive
Discussion in 'Off Topic Hot Rods & Customs' started by 56longroof, Sep 14, 2015.
  1. 56longroof
    56longroof
    Anyone got an T85 or know of one for sale. I'm not sure how well the T86 od is going to hold up behind my new engine.
  2. JeffB2
    JeffB2
    from Phoenix,AZ
  3. 56longroof
    56longroof
  4. Mark T
    Mark T
    A hot flathead will break a T-86
  5. 56longroof
    56longroof
    Yes I know. If I cant find one I will just have to baby it until I either get one or do a T5 swap.
  6. JeffB2
    JeffB2
    from Phoenix,AZ
  7. Mark T
    Mark T
    There's one for sale in the cl***ifieds
  8. 56longroof
    56longroof
    Mark, did you happen to see what the sellers name was? I did a search and found some 3 speeds but none had overdrive.
  9. Mark T
    Mark T
  10. 56longroof
    56longroof
    Thank you kind sir.
  11. koolmercuryman
    koolmercuryman
    from iowa
    don't but one with the 16 spline tail shaft, because you can't find one.
  12. 56longroof
    56longroof
    I was hoping to find one with the tailshaft yoke and the shift linkage . None of what I have on the t86 will interchange that I know of.
  13. Mark T
    Mark T
    16 spline driveshaft yokes are hard to find but if you look hard enough you'll find one.
  14. Mark T
    Mark T
    Are you going to put a floor shifter in it?
  15. 56longroof
    56longroof
    Probably not. I have heard that the overdrive makes it difficult to use a floor shifter. I don't mind the column shifter and an added bonus is it is a good theft deterrent.
  16. Mark T
    Mark T
    Did you buy the T-85 transmission?
  17. 56longroof
    56longroof
    Not yet. I sent a message but haven't heard back yet from a couple people.
  18. 56longroof
    56longroof
    Found one-maybe. Contacted Owens (Thanks Jeff) he has one out of a 60 or 61 Ford. He is checking on the shift linkage to see if it is different than my T86's. Will I need to have my driveshaft reworked? And if so any recommendations in the Missouri /Illinois /Iowa area on shops to do this?
