Hot Rods Tabs on wishbones?
Discussion in 'The Hokey Ass Message Board' started by 001slick001, Feb 2, 2018.
  1. 001slick001
    001slick001
    New guy here. I got these wishbones and am wondering what the tabs are for. Also is the curved part the top or the flat part,or does it matter. Thanks for the help.
  2. Anderson
    Anderson
    Only thing I can figure is shocks or an anti sway bar. Both very inefficient with the placement.
    001slick001 likes this.
  3. A Boner
    A Boner
    Their placement might soften the ride if they were used with some "stiff***" shocks.
  4. Anderson
    Anderson
    Also, the top one is upside down, the bottom one correct.
    mike bowling and 001slick001 like this.
  5. Happydaze
    Happydaze
    Tabs - to attach safety ties to keep them out of the dirt in the case of catastrophic failure?
    Chris
    zzford and 001slick001 like this.
  6. 1946caddy
    1946caddy
    from washington
    The tabs would be on the top, not the bottom then.
    Probably place to mount side lights to see around corners.
    001slick001 and Texas Webb like this.
  7. mike bowling
    mike bowling
    Camera 2-20-09 095.jpg Tabs were on the bottom. If it was a spring behind set up, they were probably for shocks ( although they do look kind o small).02
  8. mike in tucson
    mike in tucson
    from Tucson
    Beau and 001slick001 like this.
  9. mike bowling
    mike bowling
    mech. rods run pretty parallel to the frame and up higher, but if they were custom brackets you could on to something. That small tab opposite the ground strap is where the stock anti chatter bracket goes 2-2-12 035.jpg
