Technical tac issue
Discussion in 'Traditional Hot Rods' started by WP38, Nov 2, 2017.
  1. WP38
    WP38
    Would there be a test to determine if the tac signal is working coming from the cap?
    I checked the connection seems ok. Stopped working after I had it disconnected to put a rebuilt transmission in. The light works on the tac so I ***ume ground is not a problem. found the issue with the lead to ignition switch
