Hot Rods tach drive ratio adapter question
Discussion in 'The Hokey Ass Message Board' started by secnwind, Jul 10, 2025.
  1. secnwind
    secnwind
    I plan to use a late 50s Corvette tach drive generator and SW 5000 tach... the generator pulley is 3" diameter and the crank pulley is 6 1/2" diameter (324 Olds)... what ratio adapter will I need?... Thanks for the help...
  2. squirrel
    get it put together without an adapter, and see how far off it is, and go from there?
    jaracer likes this.
  3. nochop
    nochop
    from norcal
    Talk to rusty
    squirrel likes this.
  4. Joe H
    Joe H
  5. alchemy
    alchemy
    If you don’t have a way to check the RPMs a different way (wire up an electric tach temporarily), you will need to find the diameter of the original Vette crank pulley. Then you could find the difference in cir***ference between the old and the current pulleys. That would be needed to see what percentage you are off.
