Tach for a magneto
Discussion in 'The Hokey Ass Message Board' started by VA HAMB, Jun 21, 2007.
  1. VA HAMB
    VA HAMB
    Im in the process of restoring an original B Altered drag truck. I have all of the origional pieces except for the Tachometer. The truck runs a 401 Nailhead with a magneto.
    The original builder said he used a Sun tach with the battery pack sender. I have'nt had much luck finding one of these.
    Does anyone make a repop? My Mag does not have a port for a mechanical cable. Is there such a thing as running one off of the injection pump? Any Ideas or suggestions are greatly appreciated.:confused:
  2. Church Key
    Church Key
    Hey this project sounds fantastic, how about some pictures of your truck? I also run a B/A Fiat and I am switching to a magneto. I am a little confused as to what to do about my tach. Hopefully someone has the answer.
  3. Kurt
    Kurt
    I just went thru the same crap for my slingshot. I used a Mooneyes tach (cheapie) and the MSD magneto signal converter about $60. Works fine.
  4. Church Key
    Church Key
    Does this work with the old Vertex mag? If so where do you wire it in?
  5. silent rick
    silent rick
    i posted a similiar question. i had a vertex magneto for a small block chevy. it cost me 65 bucks to change the base over to a 354 chrysler hemi. while that was being done, it cost me an additional $125 to add a tach drive in the new base.
    there are adapters to convert the signal, but you need to shield them or else you get erradic readings.
    you can also drive a mechanical tach off the crank with this 2:1 reduction
    http://www.pegasusautoracing.com/productdetails.asp?RecID=254
  6. silent rick
    silent rick
  7. the other me
    the other me
    vertex used ta make a tach converter/signal box fer mags, as well as mallory n the above stated msd. You kin always try n contact Joe Hunt magnetos (www.huntmagnetos.com) to see if they kin hep ya or try vertex (www.taylorvertex.com) fer sum hep.
  8. VA HAMB
    VA HAMB
    Thanks for all the help guys! Great info.
    Chuch Key/ here is a pic. for ya.
  9. Jay Rush
    Jay Rush
    would a tach for a diesel that runs off a signal off the fly wheel work
  10. BigJim394
    BigJim394
    Keep checking ebay. You are looking for a Sun Model EB37A Tach Transmitter that works with 8 cyl engines using a Vertex mag. They do show up on ebay from time to time.
  11. Church Key
    Church Key
    I dig that truck, good luck with your project. There were several trucks like that running at the New England strips.
  12. I used to run an Autometer that hooked up to the mag without an adapter. This was in the early 80"s. I haven't checked to see if they're still available.
  13. I'm running an AutoMeter memory tach with a Vertex mag.
    I tried one of those signal converter boxes to run a standard ignition tach with a mag. Ya' have to run suppression wires, which I changed to, and I never got a good reading.
    The Vertex mag folks tell ya' to run solid core wires, which I already had.
    So, either "STEP-UP" for the correct electric mag tach or really "STEP-UP HIGHER" and run a mechanical tach.
  14. Just happen to remember.
    I have a Vertex Mag Auto Meter tach for sale.
    BUT ............... it's for the Vertex Mag with the external coil.
