Technical Tachometer and a Dual Coil
Discussion in 'The Hokey Ass Message Board' started by Troublemaker427, Feb 20, 2025.
  1. Troublemaker427
    Troublemaker427
    I recently purchased a car with a flathead running a Harmon Collins dual coil distributor. I would like to install an electronic tachometer. The car is converted to 12V. Will there be a problem with the dual coils and the tachometer being accurate?
  2. G-son
    G-son
    from Sweden
    Does that distributor use one coil to fire four cylinders?
    Paul likes this.
  3. Paul
    Paul
    Editor
    use a tach with a four cyl setting
    mad mikey and Troublemaker427 like this.
  4. Woodie
    Woodie
    "Troublemaker427" If your Tac has a provision to select 4-6-or 8 cyl settings, set it for 4 cyl (since your Tach is only reading one of your coils) and it will work fine.! I have the similar set up with a Flathead & "Harmon & Collins" ignition. I have an early style "Dixo" Tach, and it has the option to set the Tach up for a 4 cly setting by switching the diodes. I did that and it works just fine.!
    mad mikey, Kommuter and Paul like this.
  5. Troublemaker427
    Troublemaker427
    Exactly the information I needed Paul & Woodie. Thanks!!!
    19Eddy30, loudbang and Paul like this.
