Technical Tachometer Connection
Discussion in 'Traditional Hot Rods' started by vespaholic, Nov 13, 2025.
  1. This tach was offered to me locally.
    Will this work on my car?
    If so, how would I connect this to my A?
    If it helps here are the relevent specs on my car:
    1928 Ford Model A Roadster
    Engine: 3.3 I Flat 201ci. 4-Cylinder
    Head: Miller OHV
    Camshaft: Touring Cam (330 Lift on Intake and Exhaust and .244 Duration on Intake and Exhaust)
    Bolt-Ons: Aluminum Timing Gear and Under Drive Crank Pulley
    Ignition: FSI Electronic Ignition Centrifugal Advance Distributor Recurved for Miller Head
    Transmission: Mitchell Synchronized 3-Speed with15% Taller 1st, 2nd Gear
    Rear: Banjo 3.78:1
    Intake: Snyders Single Down Draft
    Carburetor: Stromberg 97 Chrome
    Charging: 12 V Alternator
    Exhaust: Red’s Ceramic Coated OHV Header with Smitty’s Gl***pack
  2. Moriarity
    Moriarity
    SUPER MODERATOR
  3. It was suggested that I start a new thread.
    Combine it if you think that's better.
  4. Moriarity
    Moriarity
    SUPER MODERATOR
    the tach you posted needs a sending unit. A tach match will get it going
  5. Thanks!
    I just emailed them.
    Much appreciated!
  6. Moriarity
    Moriarity
    SUPER MODERATOR
    they are the experts, make sure to send them pictures of the tach and the info on your car
  7. winduptoy
    winduptoy
    my Miller/banger OHV conversions will turn higher than 4k RPM, I don't know about yours....
    did you talk with Sean at FSI about your application? He would set your dizzy up specifically for your application.
    also...every Miller style OHV I know about and have tuned need 38-40 degrees INITIAL advance to perform...
    good luck
  8. @winduptoy The specs on my car are above. The dist. was recurved for the head by FSI. It runs great and goes faster than I'm willing to go in a 98 year old car.
