Tachometer mounting
Discussion in 'The Hokey Ass Message Board' started by Devin, Jan 18, 2013.
  1. Jalopy Joker
    Jalopy Joker
    old thread - good info
  2. Dan Timberlake
    Dan Timberlake
  3. mgtstumpy
    mgtstumpy
  4. cfmvw
    cfmvw
    While not exactly HAMB-friendly, this is how I did it in my VW: I machined an aluminum plate to replace the radio, and cast/machined a mount for the tach.
  5. Hotrodmyk
    Hotrodmyk
    Went with the windshield garnish moulding. I could not see it good enough on the column anywhere (tri-focals, you know) Wires in loom behind dash.
    cfmvw likes this.
  6. Cosmo49
    Cosmo49
    Two for one deal here, 3-on-the-tree, turn signal, I've got a busy column folks!
    RusTnut likes this.
  7. 57 HEAP
    57 HEAP
    A hose clamp might be "traditional", but I don't like the look. If you are building a car with some minor modifications or custom work and you can't do better than a hose clamp to hold the tach down, you failed.
    The Auto Meter tach I used had the bracket shown included, pretty easy. The "A" pillar mounted gauges were a little more work.
  8. Bandit Billy
    Bandit Billy
    These are available for most tachs on the market and columns ranging from 1- 3/4" to 2- 1/4" . If I remember right (fat chance) one of the AMRB winners grafted this cup and the turn signal unit together to utilize one clamp, looked perfect. Better than the hose clamp that holds the dun tach to my 68 442 column. Caution: Not cheap, something like $141.00...yeah.
  9. denis4x4
    denis4x4
    from Colorado
    That's similar to the one I used shown in post #15. You're right, not cheap
