Technical Tachometer Reccomendation
Discussion in 'Traditional Hot Rods' started by vespaholic, Nov 11, 2025.
  1. I have a '28 A with a banger.
    12V conversion
    FSI Electronic Ignition
    I'd like to run a period correct ('40's) tach.
    Can I get a recommendation?
    Anyone have one for sale?
    Thanks!
  2. tubman
    tubman
    "period correct (40's) tach" and "FSI Electronic Ignition" are in direct conflict with each other. "period correct (40's)" would be a mechanical drive tachometer and I would doubt any electronic ignition distributor would have a mechanical tach drive. If you can settle for a "Vintage Look" tach, there are a number of "old style" tachs available. A Google search will yield units from Bosch, Mooneyes, and several others. eBay in particular has a selection.
    SDS and Bandit Billy like this.
  3. Ned Ludd
    Ned Ludd
  4. I should have said Period correct looking....
    I've seen the units on eBay but most say untested and/or do not specify 4-cyl vs. 6-cyl vs. 8- cyl engine.
    So that why I was looking for a recommendation.
    Regarding if I need a tach....I don't.
    I just think a period looking tach would look cool.
    That's all
  5. Steves46
    Steves46
    from Florida
    winduptoy likes this.
  6. tarheelrodr
    tarheelrodr
    Can’t really recommend a tach but If you find a tach you like here’s an idea. check out www.technoversions.com
    I’ve got a 34 ford pu with a 59a flathead, efire distributor, 12v and a column mounted vintage Sun football tach.
    TechnoVersions sells a product TachMatch that uses a small circuit board to match any tach to any engine. Doesn’t matter if 4,6, or 8 cylinders. You can mount their small circuit board inside Sun transmitter or hide it under the dash (my preference). Works well.
    mad mikey, Deutscher, BigRRR and 2 others like this.
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    I second the tach match. I put one on my 56, they eliminate the sending unit and you can choose the number of cylinders. I think they are less than 100 bucks
    mad mikey, winduptoy and tarheelrodr like this.
  8. tarheelrodr
    tarheelrodr
    Yep, $79.99.
    mad mikey, winduptoy and Moriarity like this.
  9. jimmy six
    jimmy six
    This one “ looked” old enough for me ….. more 60’s tho. Bought it from Summit. IMG_3339.jpeg
  10. pprather
    pprather
    I'd look for a tach that max rpm is 4,000?
    Marine tachs often operate in the rpm range of a banger.
    winduptoy and Deutscher like this.
  11. tubman
    tubman
    That's a Bosch "Sun Football" tach "look-a-like". I don't think they have been discontinued. I have one and like it, but I'm a sixties guy too.
  12. Bentrodder
    Bentrodder
    from Cotati
  13. jimmy six
    jimmy six
    I wish it was a 6000 rpm but you take what you can get!
  14. Moriarity
    Moriarity
    SUPER MODERATOR
    mad mikey likes this.
  15. 62pan
    62pan
    Why fake it, find a pedestal tach drive and an early mechanical tach. Tach drive in the photo is Stewart Warner and tach is Jaeger.
    winduptoy, Deutscher and BigRRR like this.
  16. tubman
    tubman
    That's a great idea. Now, where do we find a Stewart-Warner tach drive for a FSI Electronic Ignition?
    Budget36 likes this.
  17. jnaki
    jnaki
    Hello,
    All of the tachometers for sale seem to be shiny, large and out of place in a older hot rod. Despite what motor you have, a shiny tach says out of place for the traditional 4 banger look. Look to surplus yards or shops and find one that is not shiny and chrome.
    Back when I had the 1958 Impala for my local cruising/racing mode, the tach was perfect. I also did not need to watch a big shiny chrome tach on the dash, or on the column. No need, as the C&O Stick Hydro took over at launch and it was hang on for the straight line driving. The motor/trans, shifts itself and did a great job of getting me off of the starting line first and in the lead.
    As far as aircraft gauges, again, all gauges are different from each manufacturer. When I was driving the Willys Coupe, the big shiny Sun Tach was front and center. I looked at it once at a stop light and that was it. No need to watch the needle as the sound of the motor told me when to shift. My brother told me that he looks at the tach at the starting line once and yes, that was it.
    No need to watch the tach, as long as the motor is running and one can hear how it sounds, you are in business. Even in the Impala it was the same thing. So, I decided to get a small tach. Good luck with the brand name tach makers. They were all shiny and all large.
    Jnaki
    I found a simple, smaller tachometer that would not have to be drilled on the dash, but bolted under neath the lip for a non destructive place, yet be seen, if needed.
    upload_2025-11-23_2-19-3.png The local aircraft surplus yard had several, but they were not pristine. Almost half the size of a chrome Sun Tachometer... I found it at the Army Surplus Store in Bixby Knolls. It was a series of gauges taken out of an airplane. We did see similar ones in the old Douglas Aircraft Surplus Yard, too. But, no tach. So, this one was shiny black and the owner hooked up the appropriate power source and the built in light came on brightly.
    upload_2025-11-23_2-21-45.png The small black tach that fit nicely under the lip of the dash, over to the right side of the speedometer. It covered the 120 mph mark, but at the drags, the 120 needle was pegged at the start and was useless. On the street, no one goes that fast... The built-in light was ok for night time cruising. On drag race days or nights, we never used the tach… too busy getting a two car lead at the start.
    upload_2025-11-23_2-22-51.png 58
    Impala dash placement
    The large Yellow arrow placement, was the first choice as it was directly in front of normal vision. But, it blocked the primary speedometer readings. The small arrow pointer location was an out of normal driving, front road vision at a glance, location. Nicely tucked under the dashboard lip. No harmful additional holes were added for the installation. Lit up dial inside at night, made a nice glow. YRMV
    Deutscher likes this.
  18. Budget36
    Budget36
    I wonder what kind of machining/etc., would be needed to add a mechanical drive on a distributor?
    I’ve never taken a mechanical drive one apart.
