Hot Rods Tachometer
Discussion in 'The Hokey Ass Message Board' started by easyrider47, Sep 10, 2023.
  1. easyrider47
    easyrider47
    Can anyone tell me how a single wire tach from Westach hooks up?
  2. 38Chevy454
    38Chevy454
    Well, any tach needs the negative coil hookup to determine rpm. So that's my guess as to where to connect the single wire. Negative side of coil has +12v, just with rapid cycling between +12v and zero volts when running. Your tach probably has a capacitor inside to provide a steady voltage for the operating electronics. Grounds through the case/mount. That's my best guess how it works and connections.
  3. deathrowdave
    deathrowdave
    from NKy
    The single wire tach , was normally used with Diesel engines , it was triggered off stator windings on the alternator
    427 sleeper and Bob Lowry like this.
  4. Budget36
    Budget36
    And or a sensor on the crank pulley, or on semi trucks, off the flywheel through a hole in the BH.
    Bob Lowry likes this.
  5. squirrel
