1952-59 Ford Tack Strips
Discussion in 'Off Topic Hot Rods & Customs' started by 1956Ford, Aug 12, 2011.
  1. 1956Ford
    1956Ford
    I need to reattach the roping(wind lace?) around the inside of the door frame. I was told to remove the panels around the door and install tack strips to hold in the roping. Before I start removing parts from my 56 Ford, does anyone know where is a good place to get tack strips? And any advice would be appreciated.
  2. JeffB2
    JeffB2
    from Phoenix,AZ
    Your tack strips are already there,the edges of the headliner may be hiding them from sight if you look where the old windlace is attached you will see a metal strip with points facing upward,that is your tack strip.There are no tack strips running down the sides of the door jams the flat part of your windlace is glued in there use 3M black.
  3. 1956Ford
    1956Ford
    The sides were the only loose part so 3M it is.Thanks Jeff.
