Art & Inspiration Tag lights - lets see what your using
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Jul 16, 2018.
  1. HOTRODPRIMER
    HOTRODPRIMER
    Tag lights are requirement ans we all have to have one on our cars,be it Rod or Custom so what are you using? stock or something one off? HRP
    On my Deuce sedan I stuck with Henry's original design,it's simple and it works as well now as it did in 1932.
    On the Ranch Wagon I also went with the stock tail light,I really like the way the tail light swivels to make the tag visible when the tail gate is open. HRP
  2. Bandit Billy
    Bandit Billy
    HRP, I used a Lucas unit I found on line. It has two plate markers and a reverse light in it.
    Stainless steel, look kinda vintage and required a backing plate to attach the light and plate to the spreader. I'm happy with the style of it and how it fits the frame.
    It is definitely bright!
  3. 29StudeDude
    29StudeDude
  4. sidevalve8ba
    sidevalve8ba
  5. OK, so maybe this isn't quite 'vintage'.... I tried for a vintage look. My YOM plate was a bit moth-eaten around the edges and all the original mounting holes were damaged, so I couldn't find anything in the aftermarket that would conceal that (and too cheap to buy a better plate). Plus any add-on plate light would stick up rather high and possibly be subject to damage when getting stuff out of the trunk. So I did this....
    Hand-machined in aluminum by me out of two pieces of 3/8" plate and one piece of 5/8" x 2" bar stock, with a lexan window cover. By the time I was done, there was over forty separate pieces/screws. All hardware is on the back or inside. Fully sealed against weather, with a vent to allow condensation to escape. For the light, I copied the design off a 'billet' frame including the lens (which turned out to be the hardest part to make).
    And no, the plate isn't off center in the frame; the numbers were stamped off center....
    V8-m, lothiandon1940, egads and 7 others like this.
  6. BamaMav
    BamaMav
    from Berry, AL
    No pics, but I've got a simple rectangular 3 led chrome light screwed to a plastic chrome plate frame. Looks like it was made that way.
    HOTRODPRIMER likes this.
  7. 4tford
    4tford
    Mine is on the license plate frame
  8. chevy57dude
    chevy57dude
    Billy - Nice looking Lucas unit. There's a reason for two bulbs...
  9. HOTRODPRIMER
    HOTRODPRIMER
    One of the roadsters on the all Deuce run . HRP
  10. GordonC
    GordonC
    20180423_182027.jpg Heres mine. A cheapie replica...
  11. robracer1
    robracer1
  12. Rambling Rudy
    Rambling Rudy
  13. 29StudeDude
    29StudeDude
  14. goldmountain
    goldmountain
    Was going to show my light but robracer1 beat me to it. Great light and since it is so cheap, I use them on the license plate, the plate on my teardrop, and 4 of them as courtesy lights inside the car.
    HOTRODPRIMER and robracer1 like this.
  15. mgtstumpy
    mgtstumpy
    OEM on my 35 Chebby, I had new lenses made with amber on bottom.
    HOTRODPRIMER and Bandit Billy like this.
  16. Canuck
    Canuck
    Vintage Lucas, another style:
  17. ramblin dan
    ramblin dan
    819.jpg How about these after market bad boys.
  18. Bandit Billy
    Bandit Billy
    Yeah, I know...but why the hell is the light leaking oil?
    louisb, Tim and HOTRODPRIMER like this.
  19. ct1932ford
    ct1932ford
  20. mr.chevrolet
    mr.chevrolet
  21. OzyRodder
    OzyRodder
    I'm using a 1928 Douglas motorbike taillight. Acts a a third brake light/marker light as well as lighting up the tag.
  22. Ned Ludd
    Ned Ludd
    Speaking of Lucas lights, I've always liked the "D" type, or ST51:
    They go one either side of a wide, flat plate.
    waxhead and HOTRODPRIMER like this.
  23. HOTRODPRIMER
    HOTRODPRIMER
    Mounted on both sides of the tag would give you brake lights also. HRP
  24. Gman0046
    Gman0046
    In the past when mounting a light ***embly isn't feasible I've used license plate bolts with built in lights in them. A cheap and easy fix.
    Gary
  25. HOTRODPRIMER
    HOTRODPRIMER
    Gary,I used that type of tag light bolts on my Deuce pickup. HRP
  26. WZ JUNK
    WZ JUNK
    from Neosho, MO
    Tried to delete post. No luck as you can see. Damn machine.
  27. RICH B
    RICH B
    Used a Hollywood, I found on an old bus/camper one of the hunters left in my friend's woods.
    HOTRODPRIMER and TagMan like this.
  28. oj
    oj
    I have the same unit, I'm told they are early Jaguar. Here it is in an early mockup. The bulbs are 6v, did you change yours? DSC00026.JPG
  29. lothiandon1940
    lothiandon1940
    ..............Not to be picky, Danny, but I think that's Todd Cooper's 5-window.:)
    HOTRODPRIMER and lothianwilly71 like this.
  30. lothiandon1940
    lothiandon1940
    Another view, Rodder's Journal Revival Show, 2012 @ Pimlico in Baltimore. 102_1910.jpg
    Outback, oj, akoutlaw and 2 others like this.
