Technical tail gate latches
Discussion in 'Traditional Hot Rods' started by Great Grandpa Smith, Sep 9, 2021.
  1. Guy Patterson
    Guy Patterson
    If you put a pull handle in the center of the top roll of the tailgate to pull both pins that becomes real slick
  2. Drewski
    Drewski
    I also used the seat belt buckles and s**** stainless straps to hold the tailgate when open.
    catdad49, 6sally6 and Bandit Billy like this.
  3. VERY SANO!
  4. rc57
    rc57
    I made these for my '57.
    Tman, catdad49, chevy57dude and 4 others like this.
  5. Flat Roy
    Flat Roy
    Actually pins are spring loaded. Pull the two ****ons to release and simply push back in place to secure.
    catdad49 likes this.
  6. Flat Roy
    Flat Roy
    rc57 likes this.
  7. K13
    K13
    Personally I think the seat belt latches look like an 80's street rod thing. I used small marine latches.
  8. 6sally6
    6sally6
    About those seat belt latches.........HOW do you mash the ****on on BOTH latched at the same time?!:confused:
    If you mash one....then go mash the other one.....the first one would need mashing again! Understand? (Unless you have your buddy mash one side while you do the other side!)
    6sally6
  9. I like it! More pics and details, please...
  10. I have a 5 gallon bucket of bear claw latches, nader bolts, actuator rods, that i have scavenged over the years. Just the small, basic latches. Go meander around the salvage yard, if you can fab, you can make something pretty cool that won't even be seen.
  11. warhorseracing
    warhorseracing
    from cameron wv
    While I have never done it. Those beds are only 4' wide. I would stand behind the truck and place each hand on a latch and depress them both at the same time and pull the tail gate open.
    6inarow likes this.
  12. onetrickpony
    onetrickpony
    from Texas
    I have a tailgate with hidden latches. The latches are spring loaded and connected by a cable. A handle in the middle can be twisted, pulling the cable to release both sides at once
    Guy Patterson and indyjps like this.
  13. catdad49
    catdad49
    Had this set-up on my C-10 Fleetside, luckily one of the latches always stuck! Also adapted MoPar tailgate arms and recessed them into the tailgate so that they were hidden when closed. bed 3.JPG
    Hamtown Al likes this.
  14. willys36
    willys36
    I used a late model center handle, rod actuated latch on my '53 Chevy pickup. Had to adjust the length of the rods, figure out where to mount the handle, and weld up a sheet metal cover for it but works great. Rods hide inside the tailgate roll. Sorry, didn't take more detailed pics of the installation and I sold the truck but these show how it looks finished. Plastic coated aircraft cables screwed in place on each side limit opening.
    Go to Pick-A-Part, get an import pickup tailgate with center latch, including the strike plates on the bed corners and with a little anatomy scratching, you can figure it out.
  15. K13
    K13
    They are just a standard marine latch that everyone that sells marine products seems to carry. I think I paid about $20 Cdn each for them up here. Being marine they are designed to be exposed to elements so I figure they should last. Chrome plated br***.
    cfmvw likes this.
