Tail light stands
Discussion in 'The Hokey Ass Message Board' started by Jeff J, Nov 1, 2012.
  1. Jeff J
    Jeff J
    It seems like nobody makes taillight stands for the 37 Ford taillights ! Especially that will fit on a 32 Ford . So , well you know what next has to be done ! Here's a start of making the stands !
  2. Jeff J
    Jeff J
    A little more welding and there done. Drill a extra hole in the stand for the wires to come out . They will mount on the rear frame side to the spreader bar bolt holes on the 32 ford
  3. Blue One
    Blue One
    from Alberta
    Looks pretty good, I have to come up with something for the rear of my RPU as I have a pair of the same lights.
    I think mine will be slightly different.
    I also have 2 with no licence light as my plate will be mounted elsewhere.
  4. Cerberus
    Cerberus
    Nice to see some good american know-how.
  5. Jeff J
    Jeff J
    Gona start on the plate bracket tomorrow ! Thinking something with holes !!!
  6. Bert Kollar
    Bert Kollar
    what a coincidence, here's mine I'm working on for my RPU
  7. Jeff J
    Jeff J
    Cool Bert , working on the license plate frame today on the light. All bolt on. Trying to decide if I'm gona like it !!!
  8. I just got done doing the same thing... I made a oval form the size needed and heated / bent a 3/4" strap around this form. welded the ends together. then cut a thin plate to fit inside the ovals , welded them in, marked holes in these "filler plates" for the machine screws to hold the light ***y. then welded the screws to the back side of the filler plate. Then I welded this ***y. to the side of the body after LOTS of measuring to make sure they are straight. The light can then be bolted on and removed from the car and stand by working inside the light housing without removing the interier of the car when that gets done. AND no visable bolts mounting the lights.
  9. Bert Kollar
    Bert Kollar
    Jeff, I need a license plate frame too. I attached a pic of one I'd like to build in. Hope you post when you get going
  10. Jeff J
    Jeff J
    Started on the License plate bracket today. Took a couple hours but finally got it done and I really liked it. Kinda went a little backwards but it was worth it in the end . Had the radius arm on the plate bracket it looked to long , so I took 2 " out of it . The last pic you can compair the plate bracket shortened up ! Now I'm happy with it ! Hope the cover I made will reflect the light on the plate ! The 1/4" bolts on the light that hold the plate bracket on the light ,I will replace with ****on head allens
  11. Jeff J
    Jeff J
    Worked on the headlight stands today to get the 34 truck lights on them. They have a 5/8" shaft instead of the 1/2" shaft most lights have. So a little work was involved . . !!!
  12. kwhizz
    kwhizz
    Heres what I did for my 37......Didn't like the stock ones .....too big \\
    Ken
  13. motoandy
    motoandy
    from MB, SC
    ^^^^^very nicely done
  14. That's a unique and cool look !!! Kinda different but surprisingly catchy !! Good job !!! I'll take a pair.
  15. tnich123
    tnich123
    Nice....I will take a pair as well..
