Hot Rods Tail light style: HELP!!!!!
Discussion in 'The Hokey Ass Message Board' started by miki562, Apr 6, 2017.
  1. miki562
    miki562
    Hey all, so about 2 years ago at the age of 21 I started my model a build, and so far everything's been going great! However, despite warnings from all the sages here on the HAMB, I went 'kustom' on a few things, including the tail lights. Now, I think it looks pretty cool, but what I was trying to go for was just a clean, bare bones hot rod with more go than show... and they don't really send out that message. See the pictures and, although it looks pretty neat, it kinda gives off a 60s Kustom vibe which is NOT what I'm going for.... what do you all suggest? I go for the traditional tear drop style tail lights in the rear louvered panel? Or those neat 37 ford lights that screw onto the bottom?..
    Sent from my SAMSUNG-SM-G925A using The H.A.M.B. mobile app
  2. My advice would to remove the existing lights and install a pair of '39 ford tail lights.
    brad2v and Jeff Norwell like this.
  3. Those lights?
    Ahhh............No.
    Bandit Billy and miki562 like this.
  4. miki562
    miki562
    Ok, well, suggest something!
  5. Jeff Norwell
    Jeff Norwell
    MODERATOR
    yes.... or 46-48 Ford....
    miki562, brad2v and patmanta like this.
  6. MikeRose
    MikeRose
    from Yuma, AZ
    50 pontiac would also be a cool option.
    2many projects likes this.
  7. oldolds
    oldolds
    46-48 Chevy
    59 Olds 98
    Early 50's Buick
    Model A
    Take your pick
    Chavezk21 likes this.
  8. Mr48chev
    Those have that early 70's this is all I could find a pair of at the wrecking yard yesterday look going for them. I saw too much of it back then.
    Thing is that if they aren't beat up and the chrome isn't pitted bad you can probably get enough out of them on Ebay to buy just about anything you want that works
    If that panel extends clear across and wraps around the corners or you could make it do that if you want to leave it what about making some light buckets out of short pieces of exhaust tubing that you can slightly inset 56 Chevy car tail light lenses https://www.danchuk.com/ItemForm.as...Category=7f1068a4-8b95-4945-9ce0-a4988a0b2036 In? They would go along with the 5 round holes in the panel, don't cost much and with a couple of hours of work you would have something custom that didn't look like what every other fenderless Model A was running =39 Ford 52 Pontiac.
    bp1971 likes this.
  9. BJR
    BJR
    54 Buick, simple and pointy.
  10. patmanta
    patmanta
    from Woburn, MA
    What does the rest of the car look like?
    What are your priorities as far as the build? Getting on the road or getting it perfect before you get to drive it?
    What's the period/vibe you ARE going for?
    Just Gary likes this.
  11. miki562
    miki562
    I like those questions. Well I wanted to build something Flathead powered before but I can't afford to do all that. I just went with an SBC/350 set up. However I still want to go traditional, even lakestyle
    Here's what it looks like now. I have over 680 louvered in it.
    And here's the way the **** looks now, sans ugly panel
    And this is the vibe I'm trying to give
    harpo1313 and hipster like this.
  12. patmanta
    patmanta
    from Woburn, MA
    Ok, well, It seems to me like you're going for a Function over Form aesthetic then, since you're saying lakes. Lights that look like they can be removed easily would fit with that.
    Which is getting me thinking you could use some simple, cheap, round, old trailer tail lights bolted underslung to the rear of the subframe on your body.
    You can get old ones by the box full off ePay all day and they still make some of them new for around $20/pr +/-.
    porknbeaner likes this.
  13. slv63 likes this.
  14. Gman0046
    Gman0046
    Any or no tail light would be better then what you installed.
    miki562 likes this.
  15. Rocky
    Rocky
    Classified Editor
    Well, it's pretty obvious yu can't use 50 Pontiac or any other lights in your rear panel will all those louvers so I'd go with a pair of model A or 32 ford lights on curved stands that bolt onto the sides of your rear frame horns..
    slv63, miki562 and patmanta like this.
  16. miki562
    miki562
    I was thinking something a**** the lines of these... thoughts?
  17. Sancho
    Sancho
    1941 Chevy lights mounted vertically on the ends of the rear panel (outside the louvers) might work.
  18. chop job
    chop job
    from Wisconsin
    I really like the lights.:D
    Hudson31, tb33anda3rd and miki562 like this.
  19. Squablow
    Squablow
    I think those tail lights could work if you were going for a wild show rod style, with a round tube nerf bar surrounding them or something, but from what you say, that's not the style you're going for.
    I know how hard it is to have a part that looks cool on it's own but just doesn't jibe with the rest of the build. But it's good you recognize it. Hang them up on the shop wall until the perfect use for them comes around.
    I like the idea of 41-48 Chevy car tail lights vertically in the tail panel between the body welting and louvers. The lights hung underneath on the car you have posted in post #16 I feel like only works because it's a 33/34 and the tail panel is very rounded, on a Model A freestanding tail lights like those are going to look tacked-on like an afterthought. '39 teardrops would fit too although the more square Chevy lights I think would work better with the straight rows of louvers.
    hipster, miki562 and swade41 like this.
  20. robracer1
    robracer1
    I like them, won't to look like everyone else?
    tb33anda3rd likes this.
  21. 302GMC
    302GMC
    from Idaho
    A friend with a '52 Super 88 club coupe really needs those lights .... trade you a pair of '42 -'48 Olds tails with NORS Lynx Eye blue dots for 'em ...
    miki562 likes this.
  22. flamedabone
    flamedabone
    I don't even remember what these are...37 Chevvie?? Kinda small, so there is always a risk of getting *** packed by some dip**** in a minivan, but I liked the shape of them.
    Good luck, -Abone.
    harpo1313 and Scooterville like this.
  23. miki562
    miki562
    Got pics??
  24. Gman0046
    Gman0046
    Rocky X2. I had a 32 once on which I shortened the original tail light stands which looked pretty good. That might be a good option for you.
    Gary
  25. Your pictures make me dizzy.
    Try them lights vertical, off the panel on the quarter. You might have to do a little Frenching.
    If you want the standard tried and true looks that gives you the standard tried and true tailights. There's just a few flush mount options so choosing shouldn't be difficult.
  26. I think with finessing, those would look *****in'... I'd trim the 'side' back some, and just flat cut off the back-up/reflector part. Pull them in closer to the body, a bit of custom bodywork to integrate them better and there you go... different, but 'traditional'.
    This is breaking the heart of the guy who wants them for his Olds.... LOL.
  27. Lose the louvers on the bottom panel and keep it simple, 50 Pontiac / 37 Ford etc. etc. fall hot rod pics 030.jpg fall hot rod pics 032.jpg
  28. Atwater Mike
    Atwater Mike
    Lotsa funny answers here...you wouldn't catch those *** neons on the back of my BIGGEST TRUCK!
    "Just... imagine!" Throw 'em out with the last admin.....
    miki562 likes this.
  29. swade41
    swade41
    from Buffalo,NY
    Stand those Olds light vertical with lense at bottom and fabricate a single nurf bar in line with them running across the back. The Olds lights would look as if a bumper guard type deal.
  30. 302GMC
    302GMC
    from Idaho
