Tail Light Trick!
Discussion in 'The Hokey Ass Message Board' started by roadworthy'49, Oct 21, 2010.
  1. roadworthy'49
    roadworthy'49
    I don't know if this has been posted before, but I thought I would share this little trick I figured out. My tail lights were kind of crackled and the red had faded to clear in some spots on them. The only new replacement sets I've seen are more then $500. So I went to the hobby shop and bought some of this...
    I sprayed the inside and outside, it colored it up, made the white cracks disappear, and being translucent, it still has all the light coming through.
    I didn't take any before pics unfortunately, but they were in way worse shape than the brake lights, which will be sprayed next time I take the ***embly off the trunk.
    The spray cost less than 7 bucks.
  2. Lowmerc50
    Lowmerc50
    Cool... Thanks for the tip.
  3. hillbilly4008
    hillbilly4008
    from Rome NY
    Im wondering how much it effects light going through. I know you said its transparent, but I cant imagine it being as bright as stock. Have you tried it after dark?
    great idea though
  4. roadworthy'49
    roadworthy'49
    Yeah, they light up as much as they ever did, I'll try to get a pic in the dark later.
  5. AJofHollywood
    AJofHollywood
    That turned out really well. Are you going to do the reflector above the light?
  6. roadworthy'49
    roadworthy'49
    I would like to find a replacement for that, yes
  7. JAYNE COBB
    JAYNE COBB
    from Wichita Ks
    I did this same thing for a buddy a while back. I used to see that color in a big can at the auto stores, but unfortunately they stopped making it. So yea had to get the hobby stuff. Works great! You would never know that they were painted. I did not however paint the insides so his lights look pink at night! :p
  8. fender lizard
    fender lizard
    from mcallen tx
    I've seen this before with mini truckers. I've seen it done to change clear lens to red but never thought about using it to clean up old lenses. This allows plenty of light still. Very cool, yours came out great!!!
  9. unkamort
    unkamort
    That looks pretty good! I did something similar... wanted blue back lighting for my gauge set and came up with this. 3 thin coats to get to this shade.
  10. bigalturk1
    bigalturk1
    Thanks for the info, anything for an amber front parking light?
  11. Tamiya is not traditional! Pactra or Testors please!:D:p
  12. themoose
    themoose
    Wow.....Looks brand new. Great idea.
  13. 13
    13
    from Sultan, WA
    Candy apple paint is pretty much translucent, so I think that's a great idea 49Meadowbrook!
  14. marx
    marx
    Fantastic idea-thanks for posting. I'm gonna use this trick for sure.
  15. rottenrod
    rottenrod
    dupli color makes a anodized look paint that works the same. pretty cool
  16. 61 chevy
    61 chevy
    i sparyed my clear turn lights with orange motor paint on the inside, they still light up :D
  17. And thanks for the great tip! I also put that metalic foil tape inside the buckets to reflect a little more light... Or paint the bucket insides white like someone said....
  18. tb33anda3rd
    tb33anda3rd
    looks good i will remember that trick.
  19. Cshabang
    Cshabang
    i used that trick back in 2004 while at Wyotech on my daily driver ranger..haha wouldnt you know it the next week there were "copy cats" haha it works well.
  20. cool trick! I'm gonna use that for sure
  21. Strange Agent
    Strange Agent
    I want to see night before and after pictures, but I believe it will work. I mean come on, some guys smoke their taillights with paint, right?
  22. willy3486
    willy3486
    from tennessee
    If you need taillight plastic check at a place that makes signs. I have a old 1938 seeburg jukebox and when I got it the plastic was gone. I needed some rounded plastic for the sides. I stopped at a place that made these plastic signs for stores. They use a special plastic that you can heat and form to shape. It works a lot better than standard plexigl***, I wasn't able to use plexigl***. Anyway they heat the plastic and it will form any way you want. You could make a taillight pattern like you need out of wood. Then just heat the plastic with a heat gun and push it over the wood pattern until it fills in the piece like you need. They showed me how they make a sign. All it was is a wood pattern that the plastic forms over when they heat it. The pattern had holes and they use a va***m to **** the air out of the pattern so it hold better. But something as small as a taillight you could press over with a work glove on. After I made the plastic piece for my jukebox I spray painted it like you did. I did that over 15 years ago and it still looks good. I spray painted the back side of the plastic so on the outside that you see the plastic is shiny .
  23. Antny
    Antny
    from Noo Yawk
    I use faux stained gl*** paint, available at hobby shops and crafts stores, for tail lights. I just spray the inside though, not the outside. Very light coats is the key. Works great.
  24. Candy orange works. A friend of mine used Aztek Gold but it's too yellow in my opinion.
  25. onedge
    onedge
    interesting & use the brighter bulbs too. always liked those dodges. neat -0-
  26. 23crate
    23crate
    from nz
    yes definitely works well... i did some clear lenses both red and amber --with some Testors brand kitset paint -- for a project ...
    if you are worried about the light intensity if the light bases are a little dull .. glue some Aluminum foil on to them ... makes a huge difference!!
  27. roadworthy'49
    roadworthy'49
    I tried getting a good night time shot, but you know how it goes...
    I think in this one I caught the right turn flasher
    If I had someone to hold either the camera or the brake pedal I could show how close it is to original, but I really think it's as bright now as it ever was... we are still dealing with 6v here.
    And yeah, my license plate light is out, I know.:)
  28. Stevie Nash
    Stevie Nash
    Thanks for the tip! I have one discolored tail light, and I thought I was going to have to find another one to match the good one.
  29. madpole
    madpole
    thanks. great option.
  30. Blue One
    Blue One
    from Alberta
    If the bulbs are close to the lenses, that spray on model paint will heat and bake and peel off.
    I know, it has happened to me. Looks good to begin with, then as it ages it does not do well with the heat of the bulbs.
