Tail pipes and poly tank
Discussion in 'The Hokey Ass Message Board' started by badlefihand, Nov 30, 2008.
  1. badlefihand
    badlefihand
    Tanks say's 2" min tank to pipe. No way,does this stuff melt? What did you guy's who went through this do? 47 ford. any pic's. Ya, I did the search.Really dont want side pipes.
  2. chopped
    chopped
    Mine ran along side the tank, went thru the spring and ended on the side behind the rear wheel. But , I've seen em run under the tank.
  3. Chandler Racing
    Chandler Racing
    The poly tanks will melt. I've seen a couple tanks melted through. The exhaust pipes were about an inch from it. Fab up a heat shield or see if there is a different route to go with your tailpipes.
  4. Jeff Walker
    Jeff Walker
    Ditto on seeing them melt. I can recall several years ago my dad getting a Dodge Ramcharger that had the poly tank that caught on fire from the tank melting.
  5. krylon32
    krylon32
    from Nebraska
    Absolutely will melt. With so many reasonably prices steel and stainless steel tanks out there why run a poly tank?
  6. blown240
    blown240
    from So-cal
    The guy I got my chevy from had put a poly tank in it. The exhaust actually touched it. I caught it before it melted thru, but the tank has a big divot in it now.
  7. mines about 2" away...it runs up and over the rear end and then alongside the tank
