1952-59 Ford Take 2....New (old) Ford
Discussion in 'Off Topic Hot Rods & Customs' started by Kustomline54, Dec 4, 2019.
  1. Kustomline54
    Kustomline54
    20191110_150617.jpg It's been a while, but I'm back in the game. Bought me another 1954 Ford.
    Not sure how active this group is anymore, used to log on a lot back in the day lol. Anywho thought I'd share & make a build thread.
    Quick run down, I was 21-22 when I got my 1st one. Loved it, Tore the whole thing down, pretty much snowballed into a huge project, Car was all cleaned & almost put all back together but life got in the way & I pretty much had to let her go...
    Fast forward 10yrs, I still had that '54 chip on my shoulder. By chance I went to a local junkyard with a friend & saw two '54's sittin in a gated lot next door. Stopped me dead in my tracks.
    Few months later, I decided to see if it was still there. Surprisingly it was, so I made deal & now I'm back on the 'ol HAMB 20191117_171834.jpg 20191117_171529.jpg 20191117_171706.jpg
    danman55 likes this.
  2. Kustomline54
    Kustomline54
    Here's how she was when I first saw her. Not one but TWO '54s! Never thought I'd see that. The blue one was a little rougher. When I went back a few months later it had sold... 20191204_181433.jpg 20191204_181541.jpg 20191204_181613.jpg
  3. Kustomline54
    Kustomline54
    Some pics when I sprung her from the joint! 20191204_203006.jpg 20191116_074156.jpg 20191117_172613.jpg
    customline3859 and JeffB2 like this.
  4. the-stig
    the-stig
    Nice score, looks like a lot of fun.
    Back when I was on the dark side, I think there used to be a GM yard near there.
    Kustomline54 likes this.
  5. Texas57
    Texas57
    Welcome back.....you're gonna like all the stuff Jeff has been putting together here.
    That 54 looks really solid. If it's a solid as it looks, it'll save you years and big bucks. What are your plans?
    Keep us posted.
  6. Com4tablynumb
    Com4tablynumb
    from Kodak, TN
    Awesome score....welcome home.
  7. 54vicky
    54vicky
    looks like the port a walls did not stand the test of time:eek: you are lucky to live in a state that does not need the roads salted.my car came from there.here after sitting the 2 years between you seeing it and buying it a pile of rust would have been a that remained:(as others have said a great score
  8. Kustomline54
    Kustomline54
    STIG! long time, how've you been!? I remember you being out in the i.e and going to the rotolo Chevy dealer car show. I see you're in Oregon now, hope all is great with great with you.
    JeffB2 and the-stig like this.
  9. Kustomline54
    Kustomline54
    Thank you! Yes, I've enjoying reading up on the "sticky" section. Some good info!
    Car is super straight! Except for the driver & p***enger floorboards & a 3x3 square section of the bottom of the fenders (typical) nothing that a simple patch cant fix.
  10. Kustomline54
    Kustomline54
    First thing I did when it got home was clean out all the ****/dust that's ac***ulated over the years & evicting the spiders that's been calling the '54 home, ugh! Removed the seats and all that insulation.
    Car was originally a v8/3spd. Not sure if it was with overdrive or not. Engine is long gone tho. 20191117_101814.jpg
  11. Kustomline54
    Kustomline54
    Couple more interior shots, I tried to see if I could save the seats, the vinyl looked good cleaned up but the cloth was so dry that any pressure caused it to tear. So much for that lol.
  12. the-stig
    the-stig
    Yep, got out of CA, do miss the weather and never ending car shows but not the mindless govt and soooooo many people.
    Good luck with the car.
    JeffB2 and Kustomline54 like this.
  13. Kustomline54
    Kustomline54
    Plans for the drivetrain:
    Getting 302/aod, yblock is gone so saves time. Drivers hood hinge is busted, luckily p***. side is good & lubed up. Definitely going to try to repair or replace it cheap as I can. Cant see myself spending crazy amounts on a hinge. 20191205_114012.jpg
    JeffB2 likes this.
  14. Kustomline54
    Kustomline54
    Here's the donor, '88 Merc Grand Marquis. It's heart will live on in the '54.
    JeffB2 likes this.
  15. Kustomline54
    Kustomline54
    Motor and Trans pulled, that was a damn mission! Glad that's over with.
    JeffB2 and Com4tablynumb like this.
  16. Flattop Tiki
    Flattop Tiki
    Doing the same thing with my '53, albeit much slower!
    I would appreciate photos of the hinge repair, as my p***enger side is hooped, but I got a spare with the car, so that's something on the list before inspection.
    Great progress so far!
  17. shortshift
    shortshift
    My hinges were pretty bad, both trunk and hood. What I did was take the springs off and lay the hinge pivot pins on an anvil and took a big hammer to them all. Tightened everything up nicely. I havent mounted the hood yet, but the trunk hinges ffunction nice and tight now and trunk opens and closes straight. Just dont forget to oil everything up
    Kustomline54 and Flattop Tiki like this.
  18. Kustomline54
    Kustomline54
    Thanks for the tip! Once I ***ess the hinge, I'll definitely give it a try!
  19. 50sboy
    50sboy
    Looks like a great car for starters! Welcome back and keep us up on the build!
  20. JeffB2
    JeffB2
    from Phoenix,AZ
    Kustomline54's 302 has the oil pan you will need in a 52-53 car as a '54 swap will require this one. https://www.ebay.com/itm/Dark-Blue-...965887?hash=item2cd872d73f:g:DP8AAOSwZGRbWg~x
  21. JeffB2
    JeffB2
    from Phoenix,AZ
    If you have a 52-54 Ford this is your hinges best friend apply monthly about $5 at Home Depot. 50's.jpg
  22. JeffB2
    JeffB2
    from Phoenix,AZ
    Just ran across this: https://offerup.com/item/detail/730611567/ (p***enger side hood hinge)
  23. Navyford
    Navyford
    Awesome!!! Welcome back. I’m a newer member with a 54 as well. Located in Rialto, so you’re right up the road from me.
  24. Kustomline54
    Kustomline54
    Whats up neighbor! Haha, Great Ford you got yourself! Hope to bump into you at shows once this thing is up n running.
    Navyford likes this.
  25. Kustomline54
    Kustomline54
    Small updates..
    Gutted the interior and started tackling the rusty floors. Going to finish the front & move onto the back.
    bobss396 likes this.
  26. Kustomline54
    Kustomline54
    20191216_142210_1576534968093.jpg Got my package from c2cfabrication, heard good things so thought I'd give'em a try, but man it was like pulling teeth, a lot of back & forth messaging until they finally gave notice about my item being shipped weeks after I had paid. 20191217_103036.jpg 20191217_103722.jpg 20191217_103432.jpg
    Not crazy impressed but for what they cost, it'll do.
  27. Kustomline54
    Kustomline54
    Scored a '53 style dash, always liked the way it looks over the '54s. It's a little crusty around the edges, but soda blasting should take care of that!
  28. Kustomline54
    Kustomline54
    So I took a quick glance behind the 53 dash, beside the 2 bolts on the bottom, how do you remove these 2 plates off? I'll have more time on the wknd to look over better but any input ahead of time will be appreciated so I'll have an idea going in. Thanks! 20191218_144518.jpg
  29. 54vicky
    54vicky
    I think if you undo those small nuts(carefully)they look as though they may be part of the chrome moldings and sandwich the dash panel itself.just a guess without being there.there may be 2 more at the top
  30. Kustomline54
    Kustomline54
    Thanks for the reply! I did take those 2 little nuts/bolts off & nothing budges. Nothing on top. It's always the little things that are a pain in the a** for me lol. I'm sure I'll get it, just doing some research while at work. Figures somebody has taken these dashes apart before.
