Technical Take the extra time with wiring.
Discussion in 'Traditional Hot Rods' started by xmwags, Feb 2, 2017.
  1. bct
    bct
    these are cool for controlled cleaning for grounds etc
    Chavezk21, BradinNC, Big A and 6 others like this.
  2. squirrel
    neat, I never knew that an end pilot wire brush even existed.
    Montana1, mkebaird and 1927graham like this.
  3. ct1932ford
    ct1932ford
    Bob I also went to a parochial school (how do you think I got so fu#%^ed up)? Anyway it caused me to study the chair below for sister Mary Jerold & sister Mary Harold!:eek: Good electrical training.
    Yes lots of grounds are important! :p
  4. I dislike amp meters. I byp*** them. Install a volt meter.. And use at least one wire size larger than needed. Mt .02 worth
    Ben
  5. squirrel
    This was the factory ammeter....Chrysler corp had some problems with their ammeter design. Many have been byp***ed, once someone figures out what the problem is.
  6. The37Kid
    The37Kid
    This gets mentioned all the time, has anyone ever posted a side by side photo of the wiring on these two gauges? Amp gauge = fire, Volt gauge = smaller fire? Bob
  7. bobss396
    bobss396
    This is something that you have to do in order to appreciate it. I did the same thing in a Nova bomber car. Somehow it started and ran, but developed a miss within seconds. The battery cables were hot. I had no ground between the body and engine block.
  8. Flathead Dave
    Flathead Dave
    from So. Cal.
    I will have someone else wire my car.
    The37Kid likes this.
  9. Beanscoot
    Beanscoot
    Now I finally know what these things are for!
    I used to see them at the Boeing Surplus Store in Kent, Washington.
    Capt Chap likes this.
  10. xmwags
    xmwags
    There is no point in using an ammeter with a modern style charging system. Effectively you need to run every circuit (minus the starter main feed) through the Guage to accurately measure what is being used. For instance, my father has 31 willys roadster with 6v gen and 'clap' style regulator. If the engine is working hard rpm wise, so Is the gen. So he'll or the park lights on 'relieve' some extra juice. They are primitive. I know people will hang **** on me for the sake of authenticity, but the power gen stuff is great. 12v is great. That's why we still use it. With modern solid state regulator/rectifier built in you will eradicate the need for an ammeter.
    Sent from my SM-G930F using The H.A.M.B. mobile app
  11. bct
    bct
    it would be cool to use a permanent hall effect type "clamp on " meter to feed information to an old needle gauge. authentic looking but very little risk.
  12. squirrel
    There have been cars made that do a similar thing, another way. I had a Chevy truck from the mid 60s that had a factory ammeter, but it was actually a voltmeter, that measured the voltage drop on the wire that connected the battery to the rest of the electrical system.
    I think the basic concept is called a Shunt Ammeter.
  13. bct
    bct
    bit different. hall effects measures the magnetic field created when current flows. no direct contact. nothing to burn up. transmit that to a modified stock ammeter and you are bullet proof.
    squirrel likes this.
  14. squirrel
    Sounds like the difficult way to do something that is kind of easy :)
  15. bct
    bct
    Safe is always a bit more work.
  16. moparob
    moparob
    Wiring jobs can be as easy or difficult as you make it. I've always dreaded having to run wire for any project but when I do it becomes kinda fun and definitely rewarding when your done.
    This is one of my recent endeavors..... building a stand alone efi harness out of a factory Lincoln harness and making it look good at the same time.
    Lots of hours went into tracing circuits, pin checks and removing what wasn't needed to make something useful.
    After everything is sorted out, routed, and works, I like to shield the harness with Roundit 2000, stainless tubular wire braid, silicon rubber pressure tape and tie string.
    Sent from my SM-G900V using The H.A.M.B. mobile app
    dos zetas, Yamagrant and bct like this.
  17. seb fontana
    seb fontana
    from ct
    49' Fords had that style of amp gauge, the feed wire just pasted thru a loop on the back of the gauge..
    bct and squirrel like this.
  18. bct
    bct
    Ha! There you go. A CT for DC. I bet it would cost less now than it did in 49.
  19. bchctybob
    bchctybob
    I like wiring my cars but like someone said, I hate tracing wiring issues in someone else's wiring.
    Some things I've seen a lot of over the years is;
    A short due to no grommets where wires p*** through sheet metal. Always use good grommets
    A short due to unprotected wires running past hot components. Keep wiring away from exhaust.
    Squirrely performance (sorry Jim) due to poorly crimped wire ends. At least tug on the wire end after crimping.
    On my latest acquisition, the PO added an American Autowire harness. Nice harness but it has about twice as many wires (circuits) than this car needs. So they are all rolled up and stuffed up under the dash - ugh. He also used a nice crimper that didn't crimp tight enough - I could easily pull off the wire ends, some had fallen off!
    Flathead Dave and trollst like this.
  20. bct
    bct
    I like pulling the plastic insulators off , slipping on some shrink and soldering every end, but the harness manufacturers say thats a nono. Something about breakage? Anyone ever had a broken solder joint.?
  21. squirrel
    Solder works well, if done right. Crimping works well, if done right.
  22. Bruce Lancaster
    Bruce Lancaster
    Solder can cause problems if you use too much...it wicks up the wire outside the connector, mkinf for a siff section of wire that breaks easily as stress is on a solid piece rather than 25 little wires.
    Just WATCH what happens! Heat the connector shank, feed in some solder, STOP when solder gets to the end of the shank. You only want solder within the tubular shank.
    mkebaird and bct like this.
  23. I read this whole thing thinking there would be a schematic.. HA.. Wiring up a Model A Roadster.. Buggy has a 12v Gen, Electric 16" Fan, High and Low Sealed Beams, Electric Fuel Pump and a Fuel Sending unit.. Only gauge that is juiced the the fuel gauge. Shouldn't be too troublesome but not sure how many relays to run.. I've heard 2 relays for Fan and 2 for headlights and 1 for Fuel Pump.. Seems a bit excessive. Thoughts?
  24. David Gersic
    David Gersic
    from DeKalb, IL
    Why do you need two for the fan?
    One each for the headlights, and one for the pump, yeah.
  25. Good advice OP, thanks
  26. Sheep Dip
    Sheep Dip
    from Central Ca
    All of my builds get a SS 3/8" bolt welded to the frame for the main battery ground, along with various other grounding junctions where needed or required
    Frame to engine, frame to instrument panel, tail lamps, head lamps etc. So far zero problems with electrical systems on any of them. I also always use plenty of dielectric grease.
    JPaulB likes this.
  27. CGkidd
    CGkidd
  28. bobss396
    bobss396
    I was heavy into stock cars and I apply the same thinking, what will put me out of a race? So I go with strain relief (no tight wires), enough slack so I can do a repair connection, shrink sleeve to fight abrasion, grommets, new shiny hardware for good grounds and so on.
    I also make up a wire list as I go, it may be on post-its as I go, but I make it into a single excel do***ent at the end.
  29. butchcoat1969
    butchcoat1969
    I also used a paininthe*** wiring kit as I call it was suppose to be for my 57 Chevy and it came with 15,000 wires which I didn't 14890 of them lol now I'm gonna half to buy another wiring kit from some place that actually is for my car BC I kno absolutely nothing about wiring except enough to get me in trouble lol I can't seem to get my brake lights, blinkers and parking lights to work right so it might be better if I pay someone to do it eh lol,
    Sent from my iPad using The H.A.M.B. mobile app HotRod Harry
  30. ago
    ago
    from pgh. pa.
    How do you view the images on this post with an X threw them?
