Projects Taking apart banjo rear end for storage.
Discussion in 'The Hokey Ass Message Board' started by iwanaflattie, Jul 9, 2025.
  1. iwanaflattie
    iwanaflattie
    Hey guys I need to strip a 37 ford frame,I need some parts, I need the space after I sell the frame.
    Biggest challenge is to store the banjo rear end I'm thinking taking the torque tube off and driveshaft. Is that a straight forward job?
    Any tips or tricks?
    The frame was "restored" in the recent years so it's pretty clean...
    Thanks in advance
  2. AVater
    AVater
    Removing torque tube just involves removing its bolts at the banjo end and front radius rod bolt. There are some washers, a speedometer gear and a bearing at the forward end that come out easily. You will want to note the washer bearing gear sequence for future use. Removing the driveshaft is a bit more difficult. There is a splined coupling between the driveshaft and pinion shaft. To separate them, you will need to file the heads off of two pins and then drive them out with a drift. Not difficult, but seems to take me some time.
    Hope this helps.
  3. alchemy
    alchemy
    The hardest part of removing the wishbones is getting the drums off.
    joel likes this.
  4. iwanaflattie
    iwanaflattie
    Thanks all.
    AVater likes this.
  5. rusty valley
    rusty valley
    If you want to be traditional, you just lean it up against the wall outside with the torque tube straight up to catch water. preferably in soft moist dirt to rust up all the brake parts. Thats how I usually see them at auctions
    Budget36 and AVater like this.
  6. iwanaflattie
    iwanaflattie
    No joke.
    This is one is near me for a 100 bucks.
    Maybe I'll just add juice brakes to my Banjo.
    c9dfa64786e0478cb368c9cc90fc30c7 (1).jpg b7807ec4b9c84b889a1ef50f68760d32.jpg
    rusty valley and Budget36 like this.
